Possible bug in USB 5.0 Audio class driver
johnstrohm
In file usb_audio.c, at line 146, you have:
    /* Callback to application */
    if (audio_obj_ptr->class_specific_callback.callback != NULL)
     /* notify the app of the send complete */
     audio_obj_ptr->class_specific_callback.callback(USB_DEV_EVENT_SEND_COMPLETE, USB_REQ_VAL_INVALID,NULL,0,
     audio_obj_ptr->audio_application_callback.arg);
Reformatting for readability:
                                                       NULL,
                                                       0,
I believe this should be:
                                                       NULL,
                                                       0,
                                                       audio_obj_ptr->class_specific_callback.arg);
That is, calls to the class_specific_callback should use the class_specific.callback.arg.
Labels (2)
Tags (2)
makeshi
Thanks for you raising the issue, it is a typo  issue in USB audio class driver, USB software team will fix
it in subsequent release.
