Ethernet component clock gating bug
Question asked by Peter Liedholm on Nov 19, 2014
When running init method of ethernet LDD, a hard fault occurs due to missing clock gating of a port.
This can be reproduced easily and a test program is attached.
Processor Expert Driver Suite 10.4.1 was used together with IAR 7.30.1.
/Peter
  /* THIS WILL FAIL IN ETH1 LINE 231 DUE TO PORT CLOCK NOT SET */
  /* The following two lines fixes it if uncommented */
//  /* SIM_SCGC5: PORTB=1 */
//  SIM_SCGC5 |= SIM_SCGC5_PORTB_MASK;
  device = ETH1_Init(NULL);
Original Attachment has been moved to: ETH_K64.zip
