MMC standby issue for WiFI on imx6dl board
Question asked by mrleo on Nov 18, 2014
Latest reply on Mar 22, 2015 by tao chen
Hi,all
I debug rtl8723 sdio module in android 4.4.2 system on on imx6dl board,I found that if system enter standby,after a while,resume the system.
It can not enable the wifi.
I think this is mmc standby issue about sd_write32 error.
What should I do to solve this problem?
Below are  error messages:
RTL871X: module init start
RTL871X: rtl8723bs v4.3.5_11545.20140603_BTCOEX20140507-4E40
RTL871X: build time: Nov 10 2014 17:41:13
RTL871X: rtl8723bs BT-Coex version = BTCOEX20140507-4E40
RTL871X: register rtw_netdev_ops to netdev_ops
RTL871X: rtw_wdev_alloc(padapter=dfdf1000)
RTL871X: Chip Version Info: CHIP_8723B_Normal_Chip_TSMC_B_CUT_1T1R_RomVer(0)
RTL871X: RF_Type is 3!!
RTL871X: EEPROM type is E-FUSE
RTL871X: SetHwReg8723B: bMacPwrCtrlOn=1
RTL871X: _ReadAdapterInfo8723BS, 0x4e=0xe0
RTL871X: hal_EfuseSwitchToBank: Efuse switch bank to 0
RTL871X: hal_ReadEFuse_WiFi: data end at address=0xab
RTL871X: Efuse Realmap:
29 81 03 7C 51 08 28 00 62 07 0D 45 10 00 00 00
31 31 32 32 32 32 33 33 34 34 34 EE FF FF FF FF
FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FF FF FF FF FF FF FF FF FF FF 2D 2D 2D 2D 2D 2D
2D 2D 2D 2D 2D E0 FF FF FF FF FF FF FF FF FF FF
FF FF FF FF FF FF FF FF 20 2D 1E 00 33 88 FF FF
FF 29 20 11 00 00 00 FF 00 FF 12 FF FF FF FF FF
3E 10 01 02 23 00 00 FF 20 04 4C 02 23 B7 21 02
0C 00 22 04 00 08 00 32 FF 21 02 0C 00 22 2A 01
01 00 00 00 00 00 00 00 00 00 00 00 02 00 FF FF
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 EB 00 6E 01 00 00 00 00 FF 08 D8 33 D9 E9 6D
RTL871X: Hal_EfuseParseBTCoexistInfo_8723B: Enable BT-coex, ant_num=1
RTL871X: Hal_EfuseParsePackageType_8723B phy efuse read 0x1FB =fc
RTL871X: PackageType = 0x4
RTL871X: Hal_EfuseParseVoltage_8723B hwinfo[EEPROM_Voltage_ADDR_8723B] =62
RTL871X: Hal_EfuseParseVoltage_8723B pEEPROM->adjuseVoltageVal =6
RTL871X: AutoloadFail =0,
RTL871X: Adapter->eeprompriv.EEPROMRFGainVal=f0
RTL871X: EEPRORFGainOffset = 0x29
RTL871X: SetHwReg8723B: bMacPwrCtrlOn=0
RTL871X: <==== _ReadAdapterInfo8723BS in 790 ms
RTL871X: init_channel_set ChannelPlan ID 20 Chan num:13
RTL871X: rtw_register_early_suspend
RTL871X: Init_ODM_ComInfo_8723b(): fab_ver=0 cut_ver=0
RTL871X: rtw_macaddr_cfg MAC Address  = 08:d8:33:d9:e9:6d
RTL871X: bDriverStopped:1, bSurpriseRemoved:0, bup:0, hw_init_completed:0
RTL871X: register rtw_netdev_if2_ops to netdev_ops
RTL871X: rtw_wdev_alloc(padapter=dfe5f000)
RTL871X: rtw_ndev_init(wlan0)
RTL871X: _rtw_drv_register_netdev, MAC Address (if1) = 08:d8:33:d9:e9:6d
RTL871X: rtw_ndev_init(p2p0)
RTL871X: _rtw_drv_register_netdev, MAC Address (if2) = 0a:d8:33:d9:e9:6d
RTL871X: module init ret=0
RTL871X: +871x_drv - if2_open, bup=0
RTL871X: +871x_drv - drv_open, bup=0
RTL871X: <3>sd_write32: (-84) addr=0x10948 val=0x00000280
RTL871X: <3>sd_write32: (-84) addr=0x10948, val=0x280, try_cnt=0
RTL871X: <3>sd_write32: (-84) addr=0x10948, val=0x280, try_cnt=1
RTL871X: <3>sd_write32: (-84) addr=0x10948, val=0x280, try_cnt=2
RTL871X: <3>sd_write32: (-84) addr=0x10948, val=0x280, try_cnt=3
RTL871X: <3>sd_write32: (-84) addr=0x10948, val=0x280, try_cnt=4
RTL871X: <3>sd_write32: (-84) addr=0x10948, val=0x280, try_cnt=5
RTL871X: <3>sd_write32: (-84) addr=0x10948, val=0x280, try_cnt=6
RTL871X: <3>sd_write32: (-84) addr=0x10948, val=0x280, try_cnt=7
RTL871X: <3>sd_write32: FAIL!(-84) addr=0x10948 val=0x00000280, try_cnt=8
RTL871X: rtl8723b_FirmwareDownload fw: FW_NIC, size: 30808
RTL871X: rtl8723b_FirmwareDownload: fw_ver=1b fw_subver=0001 sig=0x5301, Month=04, Date=29, Hour=13, Minute=45
RTL871X: rtl8723b_FirmwareDownload(): Shift for fw header!
RTL871X: <3>sd_write32: (-84) addr=0x11000 val=0x02ed4502
RTL871X: <3>sd_write32: (-84) addr=0x11000, val=0x2ed4502, try_cnt=0
RTL871X: [dvobj:d7137000][ERROR] continual_io_error:9 > 8
RTL871X: <3>sd_write32: (-84) addr=0x11000 val=0x02ed4502, try_cnt=0
====>_BlockWrite 110 i:0
====>_WriteFW 248
RTL871X: FWDL fail. write_fw:1, 0ms
RTL871X:  <=== rtl8723b_FirmwareDownload()
RTL871X: rtw_hal_init: hal__init fail
RTL871X: -871x_drv - drv_open fail, bup=0
RTL871X: -871x_drv - if2_open, bup=0
ADDRCONF(NETDEV_UP): p2p0: link is not ready
RTL871X: cfg80211_rtw_set_power_mgmt(p2p0) enabled:1, timeout:-1
RTL871X: cfg80211_rtw_flush_pmksa(p2p0)
RTL871X: cfg80211_rtw_change_station(p2p0)
RTL871X: [dvobj:d7137000][ERROR] continual_io_error:10 > 8
RTL871X: <3>sd_write32: (-84) addr=0x10948 val=0x00000280, try_cnt=0
RTL871X: rtl8723b_FirmwareDownload(wlan0) tmp_ps=0
RTL871X: _FWDownloadEnable: !!!!!!!!Write 0x80 Fail!: count = 101
RTL871X: _8051Reset8723: Finish
RTL871X: _FWFreeToGo: Polling FW ready Fail! (1, 0ms), REG_MCUFWDL:0x00000001
RTL871X: FWDL fail. write_fw:0, 10ms
RTL871X: LeaveAllPowerSaveMode(p2p0): bup=0 Skip!
RTL871X: rtw_p2p_enable: bDriverStopped=0, bup=0, hw_init_completed=0
Leo
