Dear all,
The SW4 of MMPF0100 has VTT mode.
When using F1 part number, SW4 is already programmed.
In MMPF0100F1, if SW4 is used as VTT mode, is SW4 of MMPF0100F1 re-programmable as VTT mode?
Yuuki
Solved! Go to Solution.
Please use the non-programmed device (“NP”) for specific options.
OTP can be once programmed.
~Yuri.
According to Table 10 (Start-up Configuration) of the MMPF0100 Datasheet,
VTT mode is not supported neither by default, nor in pre-programmed configs
(No VTT).
Yuri
Dear Yuri-san,
Thank you for your support.
> VTT mode is not supported neither by default, nor in pre-programmed configs (No VTT).
We understand it.
In MMPF0100F1, is it possible to overwrite SW4 as VTT mode?
Yuuki
~Yuri.
