CW can only  debug assembler uboot code
Question asked by li rui on Nov 16, 2014
Latest reply on Nov 21, 2014 by li rui
Hi.
Board: MPC8306som
BSP:LTIB
Software tool:CodeWarrior 8.8 linux host
                      USB TAP
Step:
          1 prepare uboot elf file.
           Make these changes to the file u-boot/config.mk:
           DBGFLAGS = -g2 -gdwarf-2
           AFLAGS_DEBUG = -Wa,-gdwarf2
           OPTFLAGS = -O1
            rebuild uboot file,make uboot.bin  and uboot(elf)
            2 create CW project
             open the uboot(elf),and auto import source code . only libgcc2.c file can't be found.
             download uboot.bin to Nor Flash in address 0xff800000
            3 debug uboot code before MMU is enabled
             confiure the USBTAP,set pic address 0xff800000.
             Check the Stop on Application Launch checkbox.
             Select the Program entry point option button.
             Power on the board and attach the process.
             break the run ,
             EPPC  hard reset.
             All the CW display is assembler code not start.s source code, I can run it step by step ,the breakpoint in the source code doesn't work .
      So I suspect the problem may caused by uboot.bin and elf file,but I can't prove it.
      Where should I look back carefully?  Does lack of libgcc2.c file cause this problem?
      Thanks for any suggestion.
Original Attachment has been moved to: config.mk.txt.zip
