[iMX6Q SABRE-SD][Android4.4] Android Dialer.apk can't be used
Question asked by Huajie Wu on Nov 12, 2014
Latest reply on Nov 18, 2014 by SergioSolis
1. Test platform
* iMX6Q SABRE-SD
* Android4.4 (KitKat)
* NO touch screen. Instead, USB mouse & keyboard are used as input device and HDMI monitor is attached with SABRE-SD board.
2. Purpose
Develop phone application based on Android4.4 Dialer.apk.
3. Issue
* Step1. Launch Android4.4 Dialer.apk through "adb shell am start -n com.android.dialer/.DialtactsActivity"
* Step2. Move USB move to make outgoing call in "Dialer.apk"
However the error is raised to inform the move point is invalid.
The detailed error log is shown below.
I/ActivityManager( 2757): Start proc com.android.dialer for activity com.android.dialer/.DialtactsActivity: pid=4042 uid=10004 gids={50004, 3003, 1028, 1015}
I/PackageManager( 2757): Running dexopt on: com.android.dialer
D/dalvikvm( 4055): DexOpt: load 108ms, verify+opt 531ms, 1622876 bytes
I/InputReader( 2757): Reconfiguring input devices.  changes=0x00000004
I/InputReader( 2757): Device reconfigured: id=7, name='max11801_ts', size 1024x768, orientation 0, mode 4, display id 0
I/ActivityManager( 2757): Config changes=480 {1.0 ?mcc?mnc en_US ldltr sw768dp w768dp h951dp 160dpi xlrg port -touch -keyb/v/h -nav/h s.7}
E/        ( 2370): g2d_blit: Invalid src rect, left 0, top 0, right 768, bottom 1024, width 1024, height 768, stride 1024!
D/PhoneStatusBar( 2824): mSettingsPanelGravity = 8388661
D/ExtensionsFactory( 4042): No custom extensions.
D/dalvikvm( 2824): GC_FOR_ALLOC freed 1651K, 82% free 4910K/26904K, paused 27ms, total 27ms
I/dalvikvm-heap( 2824): Grow heap (frag case) to 14.232MB for 9830416-byte allocation
I/ContactPhotoManager( 4042): Cache adj: 1.0
E/ContactPhotoManager( 4042): No contact photo service in context: com.android.dialer.DialerApplication@419e8660
D/dalvikvm( 2824): GC_CONCURRENT freed 46K, 47% free 14464K/26904K, paused 3ms+3ms, total 29ms
D/dalvikvm( 4042): GC_FOR_ALLOC freed 154K, 8% free 2886K/3112K, paused 15ms, total 15ms
D/dalvikvm( 4042): GC_CONCURRENT freed 17K, 5% free 3291K/3464K, paused 1ms+1ms, total 15ms
D/dalvikvm( 2824): GC_FOR_ALLOC freed <1K, 47% free 14464K/26904K, paused 28ms, total 28ms
I/dalvikvm-heap( 2824): Grow heap (frag case) to 20.031MB for 6127632-byte allocation
D/dalvikvm( 4042): GC_CONCURRENT freed 107K, 5% free 3660K/3836K, paused 3ms+5ms, total 36ms
D/dalvikvm( 2824): GC_CONCURRENT freed 0K, 24% free 20448K/26904K, paused 3ms+4ms, total 27ms
D/dalvikvm( 2824): WAIT_FOR_CONCURRENT_GC blocked 24ms
D/libEGL  ( 4042): loaded /system/lib/egl/libEGL_VIVANTE.so
D/libEGL  ( 4042): loaded /system/lib/egl/libGLESv1_CM_VIVANTE.so
D/libEGL  ( 4042): loaded /system/lib/egl/libGLESv2_VIVANTE.so
E/BufferQueue( 2370): [com.android.dialer/com.android.dialer.DialtactsActivity] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
D/OpenGLRenderer( 4042): Enabling debug mode 0
D/dalvikvm( 4042): GC_CONCURRENT freed 196K, 7% free 3858K/4132K, paused 3ms+2ms, total 21ms
W/IInputConnectionWrapper( 2955): showStatusIcon on inactive InputConnection
I/ActivityManager( 2757): Displayed com.android.dialer/.DialtactsActivity: +1s714ms
I/WindowManager( 2757): Screen frozen for +823ms due to Window{41e3ce00 u0 Starting com.android.dialer}
D/dalvikvm( 2757): GC_EXPLICIT freed 1066K, 17% free 6935K/8292K, paused 5ms+6ms, total 56ms
mtp_release
adb_release
adb_open
android_work: sent uevent USB_STATE=DISCONNECTED
fsl_gadget_disconnect_event: udc enter low power mode
USB Charger Disconnected.
ID int (ID is 0)
ehci_fsl_bus_resume begins, DR
udc suspend begins
USB Gadget suspend ends
ehci_fsl_bus_resume ends, DR
ehci fsl drv resume begins: DR
ehci fsl drv resume ends: DR
USB Charger Connected.
I/EntropyMixer( 2757): Writing entropy...
usb 1-1: new high speed USB device number 9 using fsl-ehci
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
usb 1-1.3: new low speed USB device number 10 using fsl-ehci
usb 1-1.3: device v0461 p4e22 is not supported
input: PixArt USB Optical Mouse as /devices/platform/fsl-ehci.0/usb1/1-1/1-1.3/1-1.3:1.0/input/input12
generic-usb 0003:0461:4E22.0005: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-fsl-ehci.0-1.3/input0
E/EventHub( 2757): could not get driver version for /dev/input/mouse1, Not a typewriter
usb 1-1.4: new low speed USB device number 11 using fsl-ehci
D/EventHub( 2757): No input device configuration file found for device 'PixArt USB Optical Mouse'.
I/EventHub( 2757): New device: id=11, fd=182, path='/dev/input/event5', name='PixArt USB Optical Mouse', classes=0x80000008, configuration='', keyLayout='', keyCharacterMap='', builtinKeybousb 1-1.4: device v413c p2107 is not supported
ard=false, usingSuspendBlockIoctl=true, usingClockIoctl=false
I/input: DELL Dell USB Entry Keyboard as /devices/platform/fsl-ehci.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input13
InputReader( 2757): Device added:keychord: using input dev DELL Dell USB Entry Keyboard for fevent
id=11, name='PixArt USB Optical generic-usb 0003:413C:2107.0006: input,hidraw1: USB HID v1.11 Keyboard [DELL Dell USB Entry Keyboard] on usb-fsl-ehci.0-1.4/input0
Mouse', sources=0x00002002
D/EventHub( 2757): No input device configuration file found for device 'DELL Dell USB Entry Keyboard'.
I/EventHub( 2757): New device: id=12, fd=193, path='/dev/input/event6', name='DELL Dell USB Entry Keyboard', classes=0x80000003, configuration='', keyLayout='/system/usr/keylayout/Generic.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', builtinKeyboard=false, usingSuspendBlockIoctl=true, usingClockIoctl=false
I/InputReader( 2757): Device added: id=12, name='DELL Dell USB Entry Keyboard', sources=0x00000101
I/ActivityManager( 2757): Config changes=30 {1.0 ?mcc?mnc en_US ldltr sw768dp w768dp h951dp 160dpi xlrg port -touch qwerty/v/v -nav/h s.8}
D/dalvikvm( 2968): GC_EXPLICIT freed 341K, 12% free 3086K/3496K, paused 2ms+2ms, total 32ms
I/WindowManager( 2757): Screen frozen for +323ms due to Window{41c62f48 u0 com.android.dialer/com.android.dialer.DialtactsActivity}
D/dalvikvm( 2757): GC_EXPLICIT freed 431K, 18% free 6819K/8292K, paused 3ms+5ms, total 43ms
