Using PEx in the BSP for KDS
Question asked by Alessandro Vagniluca on Oct 31, 2014
Latest reply on Oct 31, 2014 by soledad
In MQX 4.1.1 the pe_demo project is provided also for KDS build configuration, but no PEx project is present in the KDS build configuration for the BSP library (the PEx project for BSP is present only in CW build configuration).
The MQX_BSP_Porting_Example_User_Guide document describes how to set up BSP for PEx with IAR or KEIL build environment.
What about KDS? How can I set up BSP for PEx in KDS build environment? Is there a setup procedure as for IAR and KEIL?
The pe_demo application needs a PEx-based BSP to run...
