SC3900 FFT
SC3900 FFT
billchadwick
I see that the SC3900 has some special FFT instructions (not available as C Intrinsics)
I would like to see an example of their use in computing small sized FFTs (4, 8 point).
AdrianR
Please have a look into the Freescale extranet shared with your company.
www.freescale.com/livelink/livelink/open/232909557
There you'll find an example of asm FFT implementation optimized for SC3900, together with other kernels that might be useful in your project.
Let me know if you have trouble accessing it.
Adrian
billchadwick
Adrian,
If you are referring to the engineering test code in FFT Kernel.zip ?
That is extremely opaque, lacks any instructions and is ill suited to re-use.
Did you mean something else ?
Bill.
