Matlab/Simulink Autocoding with the Kinetis K-series
controlgeek
I'd like to use simulink coder to automatically generate code for a Kinetis K60 Tower module. Specifically, the TWR-K60N512-KEIL. I found the "MC Development Toolbox for Kinetis" but that appears to be specifically for the ""V" series. Will it work with the "K" series and all the tower peripheral boards? Is there something else?
Paul_Tian
Hi, Controlgeek
Standing on MCU point, Matlab/Simulink only a algorithm generator. So there is no difference between K series and V series. But if you design peripheral in simulink, that is different. So it depends on what you design.
Best Regards
Paul
