P2041rdb bare minimum dTSEC ethernet driver
haider
I am trying to write a bare minimum Ethernet driver for the p2041rdb platform.
If anybody can guide to what reference code or documentation should I refer to do this.
I do have the linux SDK and also NetComm source.
I am not sure what will be the best option to move forward as the documentation is really involved. And the above references covers the feature which I don't want in my case.
Haider
scottwood
U-Boot has an independent mode driver that you may find helpful.
haider
Thanks Scott,
I also followed the series at [Which talks about the Setting Up Basic Network Drivers using DPAA]
Multicore Expert Series: Programming Data Pat|Freescale
But when I tried to access the DINK32 reference used by this series. I came across disclaimer that DINK32 no longer contain the ethernet driver. Is that right?.
veerendranathj
Hi Haider,
I too have exact requirement ... are you able to implement the DPAA driver for P2041rdb. Please share if you have any reference codes and/or tutorials.
Thanks and Regards,
Veerendranath
