i want to disable the hardware breakpoints. im using a FRDM-K22F board and using its built in boot loader for debugging using J-link openSDA 2.1. ]
thank you
roland
Hi Roland,
In order to disable breakpoints in KDS you need to go to the Breakpoints view on the Debug perspective:
Once there, you can disable the breakpoints by deselecting them:
Or you can delete the selected breakpoints by clicking on the X icon:
Another way too access the Breakpoints view is by clicking on Window>>Show View>>Breakpoints.
PS. Here is a post related to this topic that might also be helpful for you:
Best Regards!
Carlos
