Hi all,
We need solution to the problem in VPU-driver.
When we decode a small data such as 16x16, response status from the VPU is becomes a complete.
But size of result is returned "0" occasionally in response status by VPU.
Satoshi Shimoda
Solved! Go to Solution.
Hello Satoshi,
Yes, that is a very reasonable solution, thank you for posting it.
Hi all,
I found a solution.
This issue was occurred when wait a interrupt by vpu_WaitForInt function after start decoding, no interrupt was generated after decoding.
But wait a interrupt by polling and checking status with vpu_IsBusy function, it was avoidable.
Would you let me know this solution is reasonable?
Please give me a comment if there is better solution?
Satoshi Shimoda
Hello Satoshi,
