HI, I cant ON PWMA5 in Demo Board. I can enable all PWM's A0-A4 except A5. I have using Processor Expert, and Code Warrior not returns error. Other problem, enabling one PWM, all PMW's is ON, example: ACTION: Enable PMWA0 RESULT: Enable PWMA0, PWMA1, PWMA2, PWMA3, PWMA4 (except five)
ACTION: Press IRQB for disable PWMA0 RESULT: Disabled PWMA0, and no change for others
Every time you post, you need to supply the CPU type and CodeWarrior version in the subject header. You're talking details about a PWM, but since many Freeacale CPUs have these, no one has an idea what part you're talking about. I've seen you post before with this information. I'm assuming that you're still using DSP56800/code warrior 8 with a 8357? Just keep in mind not everyone is going to read every post in the forum, and so you have to provide the information each time.
Can I suggest you to log this question in our CRM system ?
The problem must be handle by our support team and may be our Third Party Unis.
Please use Freescale on line support web page. - Go to following URL: http://www.freescale.com/TechSupport - Click on Submit a Service Request. You will come to a login page. - You can submit your request through the web from there.
