In some of our MQX based solutions we are experiencing situations where the
MQX time slicing is rendered ineffective due to timing effects. As a result,
some of our task starve for unacceptably long periods of time, rendering the
system useless.
The Issue
Consider the situation depicted in the figure. We have tasks running at two
different priority levels, high and low. The High Priority group contains
one task which waits on an event, does some work and then waits on the
same event again. The low priority task group contains two tasks, dubbed LPT1
and LPT2. LPT1 is a long-running task, possibly being always ready. LPT2 is
another low prio task which is ready. Since it is never running in the figure,
it is not depicted graphically. We are running an MQX scheduler with time
slicing enabled and both low priority tasks have time slicing enabled.
When the situation depicted in the figure persists, there is no fairness in
the low priority task group. The time slice of a task is only ever incremented
in _time_notify_kernel() which runs during the timer interrupt service routine.
This point in time is marked (b). Shortly before the timer ISR is run, a high
priority task is made ready and consequently the dispatcher runs the
high priority task. This point in time is marked (a). Shortly after the timer
ISR, the high priority task again becomes blocked. Consequently, at (c), the
dispatcher runs the task at the head of the low priority ready queue, LPT1.
When _time_notify_kernel() runs at (b), it increments the time slice of HPT, if
applicable. The time slice of LPT1 is left untouched. As per the figure, if
the HPT is always running when the timer IRQ is asserted, the time slice of
LPT1 will never be incremented. Thus, LPT2 will be starved.
Triggering the Issue
We have a number of setups that exhibit the described problem. We have the
scheduler interval set at 1ms. The scheduler is called by the timer ISR, which
also runs every 1 ms. We have a bus system requiring service by a high
priority task every 1ms, nominally. The timer runs on a local oscillator,
whereas the bus service interrupt is timed through the bus. Effectively this
means that the bus interrupt runs off some other clock source. We have low
priority tasks which are ready for long periods of time, corresponding to LPT1
and we have other low priority tasks such as LPT2. The phase between HPT
becoming ready and the timer IRQ being asserted slowly drifts, according to
the beat frequency between the oscillator frequency and the oscillator
controlling the bus services. When HPT is running between two timer ISRs, we
see normal system behavior. When the HPT is running when the timer IRQ is
asserted, we see large latency for LPT2. In practice we see the system running
as expected for e.g. 50 seconds, then be unresponsive for the next 15 seconds.
Distilling from the previous paragraphs, all of the three following
conditions need to be met to have long latencies:
1. Coarse time slicing granularity.
2. A low prio task group with multiple ready tasks, at least one task being continually ready.
3. Timer IRQ asserted when a high prio task is running.
Solutions
Since all three conditions need to be fulfilled to trigger the misbehavior,
removing one of them will fix the issue.
Changing 1.) requires changes to the scheduler and dispatcher. The code
running at points (a) and (b) is part of the scheduler and written in C. The
code running at (c) is running in the dispatcher and written in Coldfire
assembler. The dispatcher has no knownledge about the offset of the time slice
length and offset within the task descriptor structure. The offset and time
slice length can vary according to compile time configuration. If I had to
guess, the MQX scheduler was never designed to accound for sub-tick
timeslices, even though the time slicing uses tick structs which allow for
sub-tick resolution.
Changing 2.) is difficult since we have large bodies of opaque code running on
our platform. And after all, it is the scheduler's responsibility to provide
fairness in a task group. Changing 2.) is difficult for us and it feels like a
hack, not like solution.
Changing 3.) is a realistic possibility in our setups with the two
plesiochronous 1ms IRQs. The scheduler interval can be set to a value
different from 1 ms. This is not a general solution since other IRQs might
still accidentally be asserted at critical points in time, trigger the
abovementioned issue. If these "misplaced" IRQs happen only sporadically,
latencies are still very acceptable.
Our favourite solution
We are thinking about changing 1.) Our changes would look as follows: During
all (a) like transfers of control from a low prio task to a high prio task we
increment the time slice of the low prio task by one. At (b), in
_time_notify_kernel, we do not only check the time slice of the task at the
head of the active ready queue, but we check the time slices of all the tasks
at the heads of all the lower priority ready queues as well. This pretty much
assures non-starvation in the lower prio task group, albeit at the cost of
tasks receiving potentially very short time slices.
Other Ideas?
Are there other options to solve the issue? Have other people experienced this
phenomenon as well? Is there a well known name for this sort of problem?
Is there a well known solution?
If scheduler works as you described, it looks like a bug.
When time slicing is enabled for both low priority tasks, these tasks have to alternate in running.
I reported it in our internal bug database and designers will analyze that.
In mean time, could you please specify your version of MQX and just for sure also MCU and your toolchain (CW/IAR/Keil,…)?
RadekS
Thank you for reporting the bug.
We are running MQX 3.7 on an MCF54418. We are using the CW Toolchain.
We have checked the release notes of MQX 3.7 up to 4.1 and have not found any mention of changes related to time slicing or fairness.
