Fail to program MC9S08PT60 using USBDM, still can not fix that, who can save my life??
shuchengzhu
I asked a question for programming  MC9S08PT60 but I could not get any answer. The problem now is it is detecting PT chip as PA chip and can't write anything in. The log files I already update them in last question.
Now I have several questions:
1, is that USBDM the only way to do the on-board programming for  MC9S08PT60?? Do we have other methods for on-board programming??
2, If the PT won't work, what kind of 8-bit MCU I can use which gets a big memory (60k) and a low power consumption?
I still think the PT would be best for me. So if anyone can help me with this question, that will be perfect. Thanks
Shucheng ZHu
pgo
Senior Contributor V
Hi Schucheng,
I have retested programming a chip with markings P9S8PT60VLH which I believe is a MC9S08PT60.  This was with the current version which corrected an identification problem.
It passed programming and verification of a full Flash image of random data.
The lag files you provided indicated that it failed an access to the RAM buffer used for programming.  I have been unable to reproduce this.
I'm sorry but cannot find any problems so I can't do much to fix the problem you are seeing.
Finally I'm unsure what you mean by on-board programming?
bye
pgo
Hi Schucheng,
bye
