I'm trying to run the hwtimer_demo.c program included in the directory C:\Freescale\KSDK_1.0.0\demos\hwtimer_demo\src
and I get an error:
\workspace.kds\test\Debug/../Includes/hardware_init.c:69: undefined reference to `DbgConsole_Init'
collect2.exe: error: ld returned 1 exit status
I presume this is an API call, but can't seem to find where it is referenced. Can anyone point me in the right direction?
Hi Jeff,
Did you build the platform library first?
C:\Freescale\KSDK_1.0.0\lib\ksdk_platform_lib\kds\K22F51212
David
Yes, the library has been built. I have used it for other projects in my workspace.
Hi Jeff,
Can you try a clean and then re-build?
Do you see the fsl_debug_console.c file in the utilities folder of your application?
If all of this is failing, could you try a new workspace?
Sorry for the hassles.
David
