SD card hot plug can not automatically mount and identify SD card
peterxia
I.mx53_smd
imx_android_R10.4
Beginning: SD car mount ok
mmc1: new high
speed SDHC card at address aaaa
mmcblk1: mmc1:aaaa SD04G 3.69 GiB (ro)
mmcblk1:
Then hot plug(manually unmount):
mmcblk1:mmc1: Card removed and resetting
controller.
mmc1: card aaaa removed
mmc1: new high speed SDHC card at
address aaaa
mmcblk2: mmc1:aaaa SD04G 3.69 GiB (ro)
mmcblk2:
and the  SD card is  not automatic mounted
SO, When I manually mount external SD card :
FAT: Directory bread(block
1975) failed
FAT: Directory bread(block 1976) failed
FAT: Directory
bread(block 1977) failed
I want to know :What is the causes of this kind of problems?
please help me.
tank you
Labels (2)
Tags (3)
CarlosCasillas
Deactivated user, do you have any recommendation for this issue?
