libXtst and libXi
Question asked by Alexandr Glukhov on Oct 8, 2014
Latest reply on Oct 15, 2014 by Yuri Muhin
Hello, I'm trying to launch java with awt on Freescale i.MX28, but I have a problem with libXtst and libXi.
I need this files, but link is not available: http://www.imxdev.org/wiki/images/9/91/Libxtst_libxi_specs.tar.gz
So, I find files on http://packages.ubuntu.com/en/utopic/libxtst-dev
then put
libXi.spec in ltib/dist/lfs-5.1/libXi/
libXtst.spec in ltib/dist/lfs-5.1/libXtst/
.tar and .patch in ltib/rpm/SOURCES
and add into ltib/config/userspace/packages.lkc
config PKG_LIBXI
    depends CAP_HAS_MMU
        select PKG_XORG_SERVER
    select PKG_LIBXMU
    select PKG_LIBXPM
    bool "libXi"
    help
      X.Org X11 libXi runtime library
config PKG_LIBXTST
    depends CAP_HAS_MMU
    select PKG_LIBXMU
    select PKG_LIBXPM
    bool "libXtst"
    help
      X.Org X11 libXtst runtime library
and into ltib/config/userspace/pkg_map
PKG_LIBXI                        = libXi
PKG_LIBXTST                      = libXtst
After that I find packages libXtst and libXi in ./ltib -m confid in X11 package.
But when I do ./ltib, I get this error:
Processing: libXi
dropping %name-%version.tar
in spec token: sources
dropping %name-%version-%release.patch
in spec token: patches
Build path taken because: no prebuilt rpm,
Use of uninitialized value $file in concatenation (.) or string at ./ltib line 780.
rpmbuild --dbpath /home/ubuntu/Projects/TionPro28/ltib/ltib/rootfs//var/lib/rpm --target arm --define '_unpackaged_files_terminate_build 0' --define '_target_cpu arm' --define '__strip strip' --define '_topdir /home/ubuntu/Projects/TionPro28/ltib/ltib/rpm' --define '_prefix /usr' --define '_tmppath /home/ubuntu/Projects/TionPro28/ltib/ltib/tmp' --define '_rpmdir /home/ubuntu/Projects/TionPro28/ltib/ltib/rpm/RPMS'  --define '_mandir /usr/share/man' --define '_sysconfdir /etc' --define '_localstatedir /var' -bb --clean --rmsource  /home/ubuntu/Projects/TionPro28/ltib/ltib/dist/lfs-5.1/libXi/libXi.spec
Building target platforms: arm
Building for target arm
error: failed build dependencies:
  asciidoc is needed by libXi-1.7.4-alt1
  libX11-devel is needed by libXi-1.7.4-alt1
  libXext-devel is needed by libXi-1.7.4-alt1
  libXfixes-devel is needed by libXi-1.7.4-alt1
  xmlto is needed by libXi-1.7.4-alt1
  xorg-inputproto-devel is needed by libXi-1.7.4-alt1
  xorg-sgml-doctools is needed by libXi-1.7.4-alt1
  xorg-util-macros is needed by libXi-1.7.4-alt1
Build time for libXi: 0 seconds
Failed building libXi
I try apt-get install, but there is no changes. Something wrong with dependencies? Can anybody help me with this dependencies or advise another way of installing libXtst and libXi?
Thanks in advance
