games are not playing well
hariprasathgopa
Hi,all
I use a custom board similar to sabresd. And bsp is android kitkat. When I run games and have follow error, and don’t running success:
E/Unity   ( 3230): findConfigAttrib (30e1): EGL error: 0x3004
E/Unity   ( 3230): findConfigAttrib (30e2): EGL error: 0x3004
E/Unity   ( 3230): findConfigAttrib (3147): EGL error: 0x3004
whether my GPU is enable, if so how to check the usage of GPU
Why? And how to resolved?
Hari
Labels (4)
SergioSolis
I did a quick search in the internet and found someone that had the same problem that you have:
http://forum.unity3d.com/threads/angry-bots-example-crash-on-start.127199/
Not sure if it would apply to your problem in the same way, are you able to try it?
