MP3V5010 offset sits at 0.8V not 1/2 of VSS
Question asked by Jerry Korten on Oct 6, 2014
Latest reply on Oct 7, 2014 by Jerry Korten
What is the reason for this? I would expect 1/2 of VSS or 1.5V nominally. Does this mean the pressure transducer does not respond equally to positive and negative pressures? If it is OK for + and -, then do you recommend a level shifting schema (instrumentation amp in my application would be expensive)? Or is there another transducer that you'd recommend instead that runs at 3V?
Thanks.
