what will happen if i given a power supply without sd card.. it will display anything?
Hi THANGAMEENA
if any boot mode fails, processor will go to to Serial Downloader mode
described in sect.8.2.4 Serial Downloader IMX6SLRM
or try recovery mode described in sect.8.9 Recovery Devices:
The Chip supports recovery devices. If primary boot device fails, boot ROM
will try to boot from recovery device using one of I2C or ECSPI ports.
For enabling recovery device BOOT_CFG4[6] fuse must be set.
now i am preparing my sd card.. i run the script.. fsl-sdcard-partition.sh.. it will created four partition only
data
system // mysystem.img is 700 mb but it created only 450 mb .. unable to copy
cache
vendor
but we need boot and recovery partition too to put boot.img and recovery.img
how to flash sd card.
Hi THANGAMEENA
for flashing problems please create new thread.
~igor
It depends upon your boot mode settings?
