Xtrinsic FXLS8471Q Demonstration Software User Guide problem
richardhochschi
The Xtrinsic FXLS8471Q Demonstration Software User Guide, Sect. 1.2, Step 4, says to drag and drop the file named MSD-FRDM-KL25Z_Pemicro_VERSION.SDA into BOOTLOADER and implies that it is the folder named Necessary Freedom Images. I can find neither this folder nor the file. Same problem with another file, same folder, at Step 6. Thanks for the help. Richard
Jorge_Gonzalez
Hello Richard:
I think the guide assumes you already downloaded the software package mentioned in Section 2 Software Installation. The package is called FXLS8471QDEMOSW.zip and you can get it from the next link under "Lab and Test Software":
±2g/±4g/±8g, Low g, 14-Bit Dig|Freescale
Regards!,
Jorge Gonzalez
Jorge_Gonzalez
Hello Richard:
Regards!,
Jorge Gonzalez
