"Flash File To Target" fails with; "0 Bytes Programmed, Check Restricted Address Range"
Question asked by Thomas Monthei on Sep 30, 2014
Latest reply on Aug 4, 2015 by Jorge_Gonzalez
I'm using the "Flash File To Target" utility of CW 10.5 for K60 and get failure "0 Bytes Programmed, Check Restricted Address Range". Code works fine in debug/RAM and debug/FLASH but I cannot write my application to flash.  Where should I look to fix this?  I tried to modify the target task by un-checking the "Restrict to Addresses in this Range" box but this didn't help.
Thanks!
