Solved! Go to Solution.
PC
relative address is not in the range of a signed byte (smaller than -128 or bigger than 127). An 8 bit signed PC
relative offset is expected in following instructions: Branch instructions BCC, BCS, BEQ, BHCC, BHCS, BHI, BHS, BIH, BIL, BLO, BLS, BMC, BMI, BMS, BNE, BPL, BRA, BRN, BSR
Third operand in following instructions: BRCLR, BRSET
PC
