Re: Adding a Sound CODEC To IMX6
saurabh206
Senior Contributor III
Dave
You also need to add interface file between iMX6 and Coded.
You can refer wm8962 for more reference.
Saurabh
freewaymad
Thank you for your reply. This leads me in the right direction. I found the i.MX_6Dual6Quad_BSP_Porting_Guide.pdf. Chapter 8 "Porting Audio Codecs to a Custom Board" referenced this.
Thanks again,
