Device Tree Binding for Marvell DSA
kesav123
was there any patch available for the below mentioned issue ? I was facing the same problem (using linux-fsl-sdk-v1.6) with a different board.
dev_to_net_device() (net/dsa/dsa.c) is failing for the fsl Ethernet driver. It looks like , it works fine for other in-tree Ethernet drivers. Looking for some help here !!!
Link to the description of issue.
Re: Device Tree Binding for Marvell DSA on P1023RDB — Linux Network Development
-Thnx,
Kesav.
Tags (2)
jagsgediya
Hi Kesav,
We are using the marvell 88e6065 switch with the imx6 processor. If you have successfully configured the marvell switch related changes in the device tree then could you please share it?
jags
