i.MX6Q/BSP3.10.17 LPCM/MPEG-2 with gStreamer
Question asked by Nori Shinozaki on Sep 25, 2014
Latest reply on Oct 28, 2014 by gusarambula
My customer is developing using i.MX6Q and BSP 3.10.17.
They would like to use LPCM in MPEG2-PS, and asking the spec such as bit rates, bit width and depth.
Are LPCM and MPEG2-PS supported in the BSP from the beginning?
As far as I checked, there is a table in  i.MX_6_Series_Yocto_Project_Multimedia_Release_Notes.pdf.
I'm not sure this PCM means LPCM and the MPG2 includes Program Stream or not.
I also checked "audio/x-raw-int" fields by # gst-inspect in QSabreSD, however the results is not satisfaction.
# gst-inspect wavenc
  SINK template: 'sink'
    Availability: Always
    Capabilities:
      audio/x-raw-int
                   rate: [ 1, 2147483647 ]
               channels: [ 1, 2 ]
             endianness: 1234
                  width: 32
                  depth: 32
                 signed: true
      audio/x-raw-int
               channels: [ 1, 2 ]
             endianness: 1234
                  width: 24
                  depth: 24
                 signed: true
      audio/x-raw-int
               channels: [ 1, 2 ]
             endianness: 1234
                  width: 16
                  depth: 16
                 signed: true
      audio/x-raw-int
               channels: [ 1, 2 ]
                  width: 8
                  depth: 8
                 signed: false
      audio/x-raw-float
               channels: [ 1, 2 ]
             endianness: 1234
                  width: { 32, 64 }
# gst-inspect wavparse
      audio/x-raw-int
             endianness: 1234
                 signed: { true, false }
                  width: { 8, 16, 24, 32 }
                  depth: [ 1, 32 ]
                   rate: [ 1000, 192000 ]
               channels: [ 1, 8 ]
# gst-inspect auparse | more
  SRC template: 'src'
    Availability: Sometimes
    Capabilities:
      audio/x-raw-int
               channels: [ 1, 2147483647 ]
             endianness: { 1234, 4321 }
                  depth: [ 1, 32 ]
      audio/x-raw-float
                  width: { 32, 64 }
# gst-inspect osssink
Pad Templates:
    Capabilities:
      audio/x-raw-int
             endianness: { 1234 }
                  width: 16
                  depth: 16
               channels: [ 1, 2 ]
      audio/x-raw-int
                  width: 8
                  depth: 8
               channels: [ 1, 2 ]
Nori Shinozaki
