I am using MK60DN512VLL10 controller in our project.
By mistake, Instead of using port pin as digital output pin, I have used adc pin.
Now is there any possible way to use the adc pin as digital IO pin
kindly refer to the below attachments (schematics)
Solved! Go to Solution.
Hi Amreen,
I am sorry, but ADC1_DM1 pin of K60 can only be used as ADC function, so you might have to connect another pin to the circuit by flying wire. Sorry for the inconvenience that might cause.
Kan
Hi Amreen,
Kan
