I compiled android 4.4.2 accordian PDF for sd Card for sabre kit and everything works fine. Next step I want customize image and I want to add some *.apk files bbut when I use PRODUCT_COPY_FILE += your/build/tree/$FILE:path/to/location/on/device/$FILE Android is not compiling correctly with error that Prebuilt apk found in PRODUCT_COPY_FILES etc. How can I add some apk file to image in simple way?
Thank You an
You can try using ADB to install apk's.
Have you used it before?
This may help:
Sergio
