What's the different between gpu-viv-bin-mx6q-hfp and gpu-viv-bin-mx6q-sfp‏
raybloodworth
   There are "hfp" and "sfp" libs in gpu-viv-bin-mx6q-3.10.17-1.0.0.
   Could anyone tell me what's the different between hfp andg sfp?
   For board mcimx6q-sdb,which libs should I use?
   I build "core-image-weston" with yocto imx-3.10.31-1.1.0_beta.It was hf by default.
   Could anyone tell me how to build the sf version?
Labels (4)
Hi lingxin
sfp - software floating point, hfp - hardware floating point.
I.MX6 cortex a9 has hardware floating point support (neon)
so software image may be generated with or without hardware floating point support.
Please look below for details
https://community.freescale.com/thread/312094
Cortex-A9 HardFP Support | Zedboard
Regarding building details I believe most accurate answer you
can receive on meta-fsl-arm mailing list
https://lists.yoctoproject.org/listinfo/meta-freescale
raybloodworth
Thanks for your reply!
I got this from mailing list.
Restart a clean build and add the followed line into your local.conf:
DEFAULTTUNE_mx6 = "cortexa9-neon"
BTW, if I use the gpu-viv-bin-mx6q-hfp, should I use "arm-linux-gnueabihf-gcc" to compile program ?
wallyyeh
Contributor V
this post really saved my day.
