MCF5485 FEC inverted CRC
Question asked by Alexey Minkov on Sep 18, 2014
Good afternoon. Information on MCF5485.
FEC0 through MII is connected to the transmitter KSZ8051 next is plug on itself.
Did initialization FEC0 below is attached.
Made a simple program written in the FIFO and the reader.
Look at the results, the data came, and on a bad CRC.
The coup is at the stage of issuance.
How to get rid of this?
I.e. If I have a personal computer, give the package, everything is fine.
And when trying to transfer from the PC, the FEC0 CRC error.
In p. "31.4.2.2 Transmit Frame Control Word (TFCW) indicates that the 1 Transmit the CRC sequence inverted after the last data bye (regardless of the TC value)» how to get rid of this?
   move.l  #0x80009024,a1        //#ECR0    Сброс всех регистров FEC0
             move.l  #0x00000001,(a1)
             nop
             nop
             move.l  #0x80009008,a1   //#EIMR0
             move.l  #0x00000000,(a1)   //Запретить все прерывания fec0
             move.l  #0x80009004,a1                     //#EIR0    Очистить регистр прерываний FEC0
             move.l  #0xffffffff,(a1)
             move.l  #0x80009144,a1   //#FECTFWR0 Настроить Watermark: кол-во байт в FIFO, после
             move.l  #0x7,(a1)   //которого начнется передача (512)=64*(7+1)
             move.l  #0x80009118,a1   //#IAUR0    Индив.адр.назначения
             move.l  #0x0,(a1)   //Старшие 32 разряда
             move.l  #0x8000911c,a1   //IALR0    Младшие 32 разряда
             move.l  #0x0,(a1)
             move.l  #0x80009120,a1   //#GAUR0    Групп.адр.назначения
             move.l  #0x80009124,a1   //#GALR0    Младшие 32 разряда
             move.l  #0x0,(a1)
             move.l  #0x800090e4,a1   //#PALR0    Физический адр.назначения
             move.l  #0x0,(a1)   //Младшие 32 разряда
             move.l  #0x800090e8,a1   //#PAHR0    Старшие 16 разрядов
             move.l  #0x8808,(a1)
             move.l  #0x80009084,a1   //#RCR0   Receive Ctrl: max frame lenght=1518 (0x5ee)
             move.l  #0x05ee000c,(a1)         //PROM=1 (all frames); MII_MODE=1
             move.l  #0x800090c4,a1   //#TCR0   Transmit Ctrl: full duplex enable
             move.l  #0x4,(a1)
             move.l  #0x80009064,a1   //#MIBC0    MIB logic halt
             move.l  #0xc0000000,(a1)
             move.l  #0x80009200,a1   //#RMON_T_DROP0    Инициализация счетчиков
fe10:
             move.l  #0x00000000,(a1)+
             cmpa.l  #0x80009278,a1
             bne fe10
             move.l  #0x80009280,a1   //#RMON_R_DROP0
fe20:
             cmpa.l  #0x800092e4,a1
             bne fe20
             move.l  #0x80009064,a1   //#MIBC0    MIB logic enable
             move.l  #0x800091c4,a1   //#FECFRST0    Reset FIFOs
             move.l  #0x03000000,(a1)
             nop
             nop
             nop
             move.l  #0x800091ac,a1   //#FECTFCR0    Transmit: Frame mode enable;
             move.l  #0x09340000,(a1)         //last transfer granularity = 1; FIFO underflow mask
             move.l  #0x8000918c,a1   //#FECRFCR0 Receive: аналогично transmit
             move.l  #0x09140000,(a1)
             move.l  #0x800091c8,a1   //#FECCTCWR0    CRC enable
             move.l  #0x800091b8,a1   //#FECTFAR0    Trans Alarm - 1023
             move.l  #0x200,(a1)//512
             move.l  #0x80009198,a1   //#FECRFAR0    R Alarm - уст.,когда осталось 768 байт
             move.l  #0x00000002,(a1)
             move.l  #0x80009044,a1
             move.l  #0x000000B0, (a1)
             move.l  #0x80009040,a1   //4
             move.l  #0x509201E1, (a1)
             move.l  #0x80009040,a1   //1
             move.l  #0x50822100, (a1)
