Ethernet and USB is not working in 3.14.3 Kernel
Question asked by Madhusudhan Seshadri on Sep 12, 2014
Flashed the Uboot and uImage binaries on to the Frescale's iMX6 SABRE board in SD Card.
Followed the steps/procedure in the below URLs for downloading the BSP and building the binaries.
https://github.com/Freescale/fsl-community-bsp-platform
Facing two issues: Connected USB Mass Storage device (USB Memory Stick) in micro USB port and Ethernet Cable to SABRE Board and booting the system
1. The USB device is neither detecting nor enumerating, The bootup log is appended below
usb_otg_vbus: 5000 mV
usb_h1_vbus: 5000 mV
wm8962-supply: no parameters
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
ehci-mxc: Freescale On-Chip EHCI Host driver
ci_hdrc ci_hdrc.1: doesn't support gadget
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usb_otg_vbus: disabling
mount: mounting usbfs on /proc/bus/usb failed: No such file or directory
2. The board is not assigned any IP address. Issued "udhpc" command to get the IP address
udhcpc (v1.20.2) started
fec 2188000.ethernet eth0: Freescale FEC PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=2188000.ethernet:01, irq=-1)
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready Sending discover...
libphy: 2188000.ethernet:01 - Link is Up - 100/Full
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Manual assigned unused IP address using following ifconfig command. IP address is assigned, but ping is not happening.
Please let me know the solution to solve these two issue.
Thanks in advance
Madhu
Original Attachment has been moved to: log_3.14.3.txt.zip
