Is it possible to setup a MQX project with Processor Expert enabled using KDS and run it on frdm-k64f?
Are the LDD the same as in Code Warrior?
I am trying to reuse an application coded with Code Warrior. I need access to the same LDD(ie CAN_LDD.h)
That threat I think, it is using PE to configure KSDK drivers. Derek Snell , can you please confirm?
Unfortunately, the MQX 4.1.1 doesn't have bsp projects with PE enabled for the KDS.
But in the case of MQX for KSDK, you can use PE to configure the KSDK drivers and perhaps use the non KSDK components (LDD) at the same time. I have never tried that. You could try.
