Ethernet for K60
Ethernet for K60
pietrodicastri
Senior Contributor II
Good morning
I would like to have the drivers for TCP/IP without MQX. Is there a chance to get??
Thank you
Tags (2)
Kan_Li
Hi Pietro,
Do you mean a bare metal TCP/IP stack for K60? If so, I think you may refer to KSDK Software Development Kit for Kinetis MCUs|Freescale , it supports lwip support, and demos for bare metal and RTOS are included in this package as well. Since there is a new space for KSDK topics already, you may ask questions regarding KSDK directly in https://community.freescale.com/community/kinetis/kinetis-software-development-kit.
Hope that helps,
Kan
Kan_Li
Hi Pietro,
Hope that helps,
Kan
pietrodicastri
Hi Kan
I have downloaded the KSDK. I don t see the ehernet support.
Is there ??
Thank You
Kan_Li
Hi Pietro di Castri,
You may find the ethernet demo in the foder of "C:\Freescale\KSDK_1.0.0\demos\lwip_httpserver_demo" or something like that.
Hope that helps,
Kan
pietrodicastri
Hi Kan_Li
Thank You for the support.
I have this situation on my demos directory. What's wrong?
I have googled for \lwip_httpserver_demo and I find a reference to the work of Adam Dunkle. Is this the stack used
for the Kinetis???
Thank You
Kan_Li
Seems you have installed the special version for KL03Z, actually there is no ethernet module on that chip, so no demo in that SDK, you should download the following version instead.
Hope that helps,
Kan
