Dear Sir or Madam,
Hello.
Refer to "51.3.2.1 Low Power Operation" in IMX6SDLRM(Rev.1).
There is description of "PMU_REG_2P5[ENABLE_WEAK_LINREG] bit".
But, I couldn't find this register.
On the one hand, I found this register in "50.7 PMU Memory Map/Register Definition" of IMX6DQRM(Rev.2).
[Question]
Why does not the "PMU_REG_2P5[ENABLE_WEAK_LINREG] bit" exist?
Does this bit exist?
Keita
Solved! Go to Solution.
Hi Keita
yes, exists please refer to attached
rev.2 Manual which soon wil be released.
chip
Hi Keita
chip
Dear chip,
Thank you for your prompt reply.
OK. I got it.
Keita
