Kinetis sleep enable/disable
Question asked by Martin Dusek on Sep 4, 2014
Latest reply on Sep 16, 2014 by Kan_Li
is there any HW control of sleep mode enable/disable in Kinetis K MCUs? I can see SMC->PMPROT register, but it is writable only once after reset.
Using a variable, setting it true or false and then checking before sleep mode entry is not an option as there is a need to disable sleep mode when an asynchronous (interrupt) event occurs.
