BeeStack project size is too big (~100MB), I can't zip it to share it by email.
Question asked by Alan Led Collins Rivera Employee on Sep 4, 2014
Dear ZigBee developers, your problems are now solved
  • First you need to identify which library you are using:
    • Open your project (IAR or CodeWarrior),
    • Check on the ZigBee/Library folder, the library name is similar to “BeeStackZrRsRNPSp2_MC13226.a”,
  • Now you can delete other libraries inside the “....\ZigBee\Libs” (just don’t remove the one you are using).
  • Then you can use 7zip (freeware) to compress the files.
Instead of ~100MB, you will have a 7zip of ~2MB.
Enjoy
