K60 144-pin TQFP pin-for-pin same across part numbers?
aes_mike
Do all the K60 144-pin TQFP parts have the same basic pinout from which I can scale up/down and so on?
For example, does a MK60N512VLQ100 have the same pinout as a MK60FN1M0VLQ15, for example?   Without having to dig through all the datasheets and compare pinouts.  Someone at Freescale must have some idea of what is pin-for-pin compatible and what is not.
My goal is to have scalability in designs as well as maximize available/possible distribution inventory available to us.
razed11
Contributor V
I found this statement:
The following table summarizes the memory and package options for the K60 family. All devices which share a common
package are pin-for-pin compatible.
In this document:
http://cache.freescale.com/files/32bit/doc/prod_brief/K60PB.pdf
I read this to be true across K6x parts.
razed11
Contributor V
In this document:
