The BSP documentations says: ...Alternatively, the bsp_cm.c can be modified manually without PEx.
It then goes on to say nothing more about it. A document about changing clock settings is referenced but I can't find it anywhere.
I'd like to understand how the clocks are configured. I'm wondering how SysTick is configured because on the K64 Freedom when I call _task_delay(10) I'm getting 150 ms instead.
Hi Kenny,
I am attaching this document, this document is located at the path: C:\Freescale\Freescale_MQX_4_1\doc\tools\cw
Sol
Thanks! A little bias towards the CW people I see. Let me see if this helps.
