Hi All -
I am developing a K21 application. My code will run fine if I download and debug from within the IAR debugger, but it will not boot on it's own.
Any ideas?
Solved! Go to Solution.
Hey Kan
I found the problem - the watchdog was not being disabled at startup.
Dan
Hi Dan,
Would you please specify the tower board version? Is it the TWR-K21F120M? and it would be better that you could send your code for a review.
Thanks for your patience!
B.R
Kan
Hi Kan -
I'm using the TWR-K21F120M. My code is based on the gpio example in the tower sample code. If I specify the 512KPflash linker file in the gpio project and download it using the Jlink the board will boot into the gpio code. When I do the same with my code it hangs unless I start it in the debugger.
What is the best way to send you my code?
Dan
Hi Dan,
That looks like a software issue, so you may attach your project here, and I will try to reproduce this issue with my TWR-K21F120M. Thanks for your patience!
B.R
Kan
Hey Kan
Dan
