LLS in processor expert
javervalino
Good day to all.
Can you share some example code on how to enter LLS mode using processor expert “(i dont have an external reference clock)”. Im having a hard time setting all parameters in CW using PEx.  :smileysad: .. Also my problem is to wake-up from this LLS using TSI interrupt. Im using kl16 mcu.
Thanks you very much..
Tags (2)
javervalino
Hi All,
Any example/suggestion here..
Thanks.
BlackNight
javervalino
Hi Erich,
I found that very useful. Thanks.
But another problem I encountered is to use the TSI as an interrupt while in LLS mode to wake-up my MCU. I cant configure it in processor expert. I cant found a good example on how to implement it in PEx.
Thanks.
