About andoird 4.4 screenrecorder
klldmofashi
Hi I recently downloaded "android_kk4.4.2_1.0.0-ga_images_6qsabresd" on my iMX6 sabresd board. Then I tried the screenrecorder program. It runs without problem, but the content it recorded is corrupted. See attached. Is there anyone who knows why and how to fix it?
P.S. I tried different resolutions. 1920x1080, 1280x720, and 1024x768. The HDMI output is correct but somehow the video recorded is wrong.
EricNelson
Senior Contributor II
I think you hit the nail on the head, Saurabh.
This appears to be an issue with the color depth of the frame-buffer (the bpp=32 clause).
The "if=RGB24" controls the video output format for your display and really can't affect this.
saurabh206
Senior Contributor III
I have tested on my custom hardware its working fine, It seems that your resolution is not set correctly.
Can You provide your logcat detail?
Saurabh
klldmofashi
I noticed that there was a line here. Do you know how to set the correct color format so that screenrecorder can support?
W/SurfaceFlinger( 2338): [ScreenRecorder] Unexpected beginFrame() in GLES state
E/        ( 2341): Not supported color format 4!
saurabh206
I am using if=RGB24,bpp=32.
You can try this.
Saurabh
EricNelson
klldmofashi
32bpp works for me. Thanks Eric and Saurabh.
klldmofashi
Hi Saurabh,
Thanks for your quick reply. The following is the logcat I get while I am running screenrecorder.
root@sabresd_6dq:/ # logcat
--------- beginning of /dev/log/main
D/MagDaemon( 2348): init_sensors
D/MagDaemon( 2348): find sensor name FreescaleAccelerometer
D/MagDaemon( 2348): input device 'FreescaleAccelerometer' opened, fd = 8
I/OrionSvc( 2349): Set command is setprop athr.gps.conf /system/etc/gps/Orion.in        i
I/installd( 2342): installd firing up
I/DEBUG   ( 2337): debuggerd: Jun 20 2014 09:23:58
D/MagDaemon( 2348): find sensor name FreescaleMagnetometer
D/MagDaemon( 2348): input device 'FreescaleMagnetometer' opened, fd = 10
D/MagDaemon( 2348): find sensor name eCompass
D/MagDaemon( 2348): input device 'eCompass' opened, fd = 11
D/MagDaemon( 2348): magnetic sensor calibrate daemon start
D/MagDaemon( 2348): magnetic calibrate daemon set threshold 100.000000
I/Netd    ( 2336): Netd 1.0 starting
W/InterfaceController( 2336): Warning (dlopen failed: library "/system/lib/libne        tcmdiface.so" not found) while opening the net interface command library
E/DirectVolume( 2335): Vold managed volumes must have auto mount point; ignoring        /mnt/media_rw/extsd
E/DirectVolume( 2335): Vold managed volumes must have auto mount point; ignoring        /mnt/media_rw/udisk
--------- beginning of /dev/log/system
I/Vold    ( 2335): Vold 2.1 (the revenge) firing up
D/Vold    ( 2335): Volume extsd state changing -1 (Initializing) -> 0 (No-Media)
D/Vold    ( 2335): Volume udisk state changing -1 (Initializing) -> 0 (No-Media)
I/SurfaceFlinger( 2338): SurfaceFlinger is starting
I/SurfaceFlinger( 2338): SurfaceFlinger's main thread ready to run. Initializing        graphics H/W...
D/libEGL  ( 2338): loaded /system/lib/egl/libEGL_VIVANTE.so
I/OrionSvc( 2349): using prop value
D/libEGL  ( 2338): loaded /system/lib/egl/libGLESv1_CM_VIVANTE.so
I/OrionSvc( 2349): Get key ANDROID_SOCKET_athrshmsocket on 11
I/OrionSvc( 2349): Enter control_ipc thread
D/libEGL  ( 2338): loaded /system/lib/egl/libGLESv2_VIVANTE.so
W/imx6.gralloc( 2338): using (fd=15)
W/imx6.gralloc( 2338): id           = DISP3 BG - DI1
W/imx6.gralloc( 2338): xres         = 1024 px
W/imx6.gralloc( 2338): yres         = 768 px
W/imx6.gralloc( 2338): xres_virtual = 1024 px
W/imx6.gralloc( 2338): yres_virtual = 2304 px
W/imx6.gralloc( 2338): bpp          = 16
W/imx6.gralloc( 2338): r            = 11:5
W/imx6.gralloc( 2338): g            =  5:6
W/imx6.gralloc( 2338): b            =  0:5
W/imx6.gralloc( 2338): width        = 163 mm (159.568100 dpi)
W/imx6.gralloc( 2338): height       = 122 mm (159.895081 dpi)
W/imx6.gralloc( 2338): refresh rate = 60.00 Hz
I/v_hwc   ( 2338): Default primary display
I/v_hwc   ( 2338): xres         = 1024 px
I/v_hwc   ( 2338): yres         = 768 px
I/v_hwc   ( 2338): xdpi         = 159.6 dpi
I/v_hwc   ( 2338): ydpi         = 159.9 dpi
I/v_hwc   ( 2338): refresh rate = 60.0 Hz
E/v_hwc   ( 2338): open /dev/graphics/fb2 failed
I/v_hwc   ( 2338): Virtual display @2 initialized.
I/v_hwc   ( 2338): Vivante HWComposer v2.4
I/v_hwc   ( 2338): Device:               0x41e06408
I/v_hwc   ( 2338): Separated 2D:         YES
I/v_hwc   ( 2338): 2D PE20:              YES
I/v_hwc   ( 2338): Multi-source blit:    NO
I/v_hwc   ( 2338): Multi-source blit Ex: NO
I/v_hwc   ( 2338): OPF/YUV blit/Tiling : NO
I/v_hwc   ( 2338): Filter stretch      : YES
I/FslHwcomposer( 2338): using viv hwc!
I/FslHwcomposer( 2338): fb0 is ldb
I/FslHwcomposer( 2338):  device
I/FslHwcomposer( 2338): fb1 is overlay device
W/FslHwcomposer( 2338): open /sys/class/graphics/fb2 failed
W/FslHwcomposer( 2338): open /sys/class/graphics/fb3 failed
W/FslHwcomposer( 2338): open /sys/class/graphics/fb4 failed
W/FslHwcomposer( 2338): open /sys/class/graphics/fb5 failed
I/FslHwcomposer( 2338): hwcomposer: open framebuffer fb0
I/FslHwcomposer( 2338): hwc_device_open,411
I/SurfaceFlinger( 2338): Using composer version 1.3
W/SurfaceFlinger( 2338): no suitable EGLConfig found, trying a simpler query
I/SurfaceFlinger( 2338): EGL informations:
I/SurfaceFlinger( 2338): vendor    : Android
I/SurfaceFlinger( 2338): version   : 1.4 Android META-EGL
I/SurfaceFlinger( 2338): extensions: EGL_KHR_get_all_proc_addresses EGL_ANDROID_        presentation_time EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_        lock_surface EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KH        R_gl_renderbuffer_image EGL_KHR_reusable_sync EGL_KHR_fence_sync EGL_ANDROID_ima        ge_native_buffer EGL_ANDROID_recordable
I/SurfaceFlinger( 2338): Client API: OpenGL_ES
I/SurfaceFlinger( 2338): EGLSurface: 5-6-5-0, config=0x411332c8
I/SurfaceFlinger( 2338): OpenGL ES informations:
I/SurfaceFlinger( 2338): vendor    : Vivante Corporation
I/SurfaceFlinger( 2338): renderer  : Vivante GC2000
I/SurfaceFlinger( 2338): version   : OpenGL ES 2.0
I/SurfaceFlinger( 2338): extensions: GL_EXT_debug_marker GL_OES_compressed_ETC1_        RGB8_texture GL_OES_compressed_paletted_texture GL_OES_EGL_image GL_OES_depth24        GL_OES_fbo_render_mipmap GL_OES_fragment_precision_high GL_OES_rgb8_rgba8 GL_OES        _stencil1 GL_OES_stencil4 GL_OES_texture_npot GL_OES_vertex_half_float GL_OES_de        pth_texture GL_OES_packed_depth_stencil GL_OES_standard_derivatives GL_OES_get_p        rogram_binary GL_EXT_texture_format_BGRA8888 GL_IMG_read_format GL_EXT_blend_min        max GL_EXT_read_format_bgra GL_EXT_multi_draw_arrays GL_APPLE_texture_format_BGR        A8888 GL_APPLE_texture_max_level GL_ARM_rgba8 GL_EXT_frag_depth GL_VIV_shader_bi        nary GL_VIV_direct_texture GL_OES_mapbuffer GL_OES_EGL_image_external GL_EXT_dis        card_framebuffer GL_EXT_multisampled_render_to_texture GL_VIV_clamp_to_border GL        _OES_vertex_type_10_10_10_2 GL_EXT_texture_type_2_10_10_10_REV GL_EXT_texture_fi        lter_anisotropic GL_OES_element_index_uint
I/SurfaceFlinger( 2338): GL_MAX_TEXTURE_SIZE = 8192
I/SurfaceFlinger( 2338): GL_MAX_VIEWPORT_DIMS = 8192
E/SurfaceFlinger( 2338): HWComposer: framebufferTarget is null
D/SurfaceFlinger( 2338): Screen acquired, type=0 flinger=0x41e03450
I/mediaserver( 2341): ServiceManager: 0x40d5e538
I/AudioFlinger( 2341): Using default 3000 mSec as standby time.
I/CameraService( 2341): CameraService started (pid=2341)
I/CameraService( 2341): Loaded "Freescale CameraHal Module" camera module
I/FslCameraHAL( 2341): Face Back Camera is ov5640_mipi, orient is 0
I/FslCameraHAL( 2341): Face Front Camera is uvc,ov5642_camera,ov5640_camera, ori        ent is 0
I/FslCameraHAL( 2341): Checking the camera ov5640_mipi
I/FslCameraHAL( 2341): Checking the camera uvc
I/FslCameraHAL( 2341): Checking the camera ov5642_camera
I/FslCameraHAL( 2341): Checking the camera ov5640_camera
I/AudioPolicyManagerBase( 2341): loadAudioPolicyConfig() loaded /system/etc/audi        o_policy.conf
W/audio_hw_primary( 2341): card 0, id wm8962audio ,driver wm8962-audio, name wm8        962-audio
W/audio_hw_primary( 2341): out rate 44100
W/audio_hw_primary( 2341): in rate 44100, channels 1 format 0
I/AudioFlinger( 2341): loadHwModule() Loaded primary audio interface from Freesc        ale i.MX Audio HW HAL (audio) handle 1
W/audio_hw_primary( 2341): open output stream devices 2, format 1, channels 3, s        ample_rate 44100, flag 2
W/audio_hw_primary( 2341): opened out stream...1074472776
I/AudioFlinger( 2341): HAL output buffer size 192 frames, normal mix buffer size        768 frames
I/AudioMixer( 2341): found effect "Multichannel Downmix To Stereo" from The Andr        oid Open Source Project
E/MonoPipe( 2341): Failed to fetch local time frequency when constructing a Mono        Pipe (res = -32).  getNextWriteTimestamp calls will be non-functional
D/libEGL  ( 2492): loaded /system/lib/egl/libEGL_VIVANTE.so
D/libEGL  ( 2492): loaded /system/lib/egl/libGLESv1_CM_VIVANTE.so
D/libEGL  ( 2492): loaded /system/lib/egl/libGLESv2_VIVANTE.so
E/BufferQueue( 2338): [BootAnimation] dequeueBuffer: can't dequeue multiple buff        ers without setting the buffer count
I/v_hwc   ( 2338): Display(0x400ca008) detected: format=209 1024x768
I/v_hwc   ( 2338): Display buffer(0x400cca70) detected: physical=0x3e400000
I/v_hwc   ( 2338): Display buffer(0x4009e950) detected: physical=0x3e580000
V/NatController( 2336): runCmd(/system/bin/iptables -F natctrl_FORWARD) res=0
V/NatController( 2336): runCmd(/system/bin/iptables -A natctrl_FORWARD -j DROP)        res=0
V/NatController( 2336): runCmd(/system/bin/iptables -t nat -F natctrl_nat_POSTRO        UTING) res=0
I/v_hwc   ( 2338): Display buffer(0x4009ecf0) detected: physical=0x3e700000
V/NatController( 2336): runCmd(/system/bin/ip rule flush) res=0
V/NatController( 2336): runCmd(/system/bin/ip -6 rule flush) res=0
V/NatController( 2336): runCmd(/system/bin/ip rule add from all lookup default p        rio 32767) res=0
V/NatController( 2336): runCmd(/system/bin/ip rule add from all lookup main prio        32766) res=0
V/NatController( 2336): runCmd(/system/bin/ip -6 rule add from all lookup defaul        t prio 32767) res=0
D/AndroidRuntime( 2339):
D/AndroidRuntime( 2339): >>>>>> AndroidRuntime START com.android.internal.os.Zyg        oteInit <<<<<<
V/NatController( 2336): runCmd(/system/bin/ip -6 rule add from all lookup main p        rio 32766) res=0
V/NatController( 2336): runCmd(/system/bin/ip route flush cache) res=0
V/NatController( 2336): runCmd(/system/bin/iptables -F natctrl_tether_counters)        res=1
V/NatController( 2336): runCmd(/system/bin/iptables -X natctrl_tether_counters)        res=1
V/NatController( 2336): runCmd(/system/bin/iptables -N natctrl_tether_counters)        res=0
D/AndroidRuntime( 2339): CheckJNI is OFF
I/AndroidRuntime( 2339): JNI options: '-Xjniopts:warnonly'
D/MDnsDS  ( 2336): MDnsSdListener::Hander starting up
D/MDnsDS  ( 2336): MDnsSdListener starting to monitor
D/MDnsDS  ( 2336): Going to poll with pollCount 1
D/dalvikvm( 2339): Trying to load lib libjavacore.so 0x0
D/dalvikvm( 2339): Added shared lib libjavacore.so 0x0
D/dalvikvm( 2339): Trying to load lib libnativehelper.so 0x0
D/dalvikvm( 2339): Added shared lib libnativehelper.so 0x0
D/dalvikvm( 2339): No JNI_OnLoad found in libnativehelper.so 0x0, skipping init
D/dalvikvm( 2339): Note: class Landroid/app/ActivityManagerNative; has 179 unimp        lemented (abstract) methods
E/memtrack( 2339): Couldn't load memtrack module (No such file or directory)
E/android.os.Debug( 2339): failed to load memtrack module: -2
I/SamplingProfilerIntegration( 2339): Profiling disabled.
I/Zygote  ( 2339): Preloading classes...
D/dalvikvm( 2339): GC_EXPLICIT freed 39K, 8% free 520K/564K, paused 0ms+0ms, tot        al 3ms
D/dalvikvm( 2339): GC_EXPLICIT freed 3K, 4% free 596K/616K, paused 0ms+0ms, tota        l 3ms
D/dalvikvm( 2339): GC_EXPLICIT freed 16K, 3% free 640K/660K, paused 0ms+1ms, tot        al 3ms
D/dalvikvm( 2339): GC_EXPLICIT freed 20K, 4% free 673K/696K, paused 0ms+0ms, tot        al 3ms
D/dalvikvm( 2339): GC_EXPLICIT freed 10K, 2% free 718K/732K, paused 0ms+0ms, tot        al 3ms
D/dalvikvm( 2339): GC_EXPLICIT freed 27K, 4% free 746K/776K, paused 0ms+0ms, tot        al 3ms
D/dalvikvm( 2339): GC_EXPLICIT freed 35K, 5% free 816K/856K, paused 0ms+0ms, tot        al 4ms
D/dalvikvm( 2339): GC_EXPLICIT freed 29K, 4% free 843K/876K, paused 0ms+1ms, tot        al 4ms
D/TextLayoutCache( 2339): Using debug level = 0 - Debug Enabled = 0
D/dalvikvm( 2339): GC_EXPLICIT freed 19K, 3% free 884K/908K, paused 0ms+0ms, tot        al 4ms
I/dalvikvm( 2339): threadid=1: recursive native library load attempt (/system/li        b/libmedia_jni.so)
D/MtpDeviceJNI( 2339): register_android_mtp_MtpDevice
D/dalvikvm( 2339): GC_EXPLICIT freed 19K, 3% free 919K/940K, paused 1ms+1ms, tot        al 5ms
D/dalvikvm( 2339): GC_EXPLICIT freed 21K, 3% free 955K/980K, paused 0ms+1ms, tot        al 5ms
D/dalvikvm( 2339): GC_EXPLICIT freed 14K, 2% free 994K/1012K, paused 0ms+1ms, to        tal 5ms
D/dalvikvm( 2339): GC_EXPLICIT freed 28K, 4% free 1020K/1052K, paused 0ms+0ms, t        otal 5ms
D/dalvikvm( 2339): GC_EXPLICIT freed 16K, 2% free 1074K/1092K, paused 0ms+0ms, t        otal 6ms
E/EmojiFactory_jni( 2339): Failed to load libemoji.so: dlopen failed: library "l        ibemoji.so" not found
D/dalvikvm( 2339): GC_EXPLICIT freed 30K, 3% free 1390K/1424K, paused 1ms+1ms, t        otal 9ms
D/dalvikvm( 2339): GC_EXPLICIT freed 35K, 3% free 1414K/1452K, paused 0ms+0ms, t        otal 8ms
D/dalvikvm( 2339): GC_EXPLICIT freed 30K, 3% free 1439K/1472K, paused 1ms+1ms, t        otal 8ms
D/dalvikvm( 2339): GC_EXPLICIT freed 38K, 3% free 1455K/1496K, paused 0ms+1ms, t        otal 8ms
I/LibraryLoader( 2339): loading: webviewchromium
I/LibraryLoader( 2339): loaded: webviewchromium
D/dalvikvm( 2339): GC_EXPLICIT freed 16K, 2% free 1498K/1516K, paused 1ms+1ms, t        otal 10ms
D/dalvikvm( 2339): GC_EXPLICIT freed 24K, 2% free 1527K/1556K, paused 1ms+1ms, t        otal 10ms
D/dalvikvm( 2339): GC_EXPLICIT freed 81K, 6% free 1572K/1656K, paused 1ms+1ms, t        otal 10ms
D/dalvikvm( 2339): GC_EXPLICIT freed 36K, 4% free 1591K/1656K, paused 0ms+1ms, t        otal 9ms
D/dalvikvm( 2339): GC_EXPLICIT freed 31K, 3% free 1616K/1656K, paused 1ms+1ms, t        otal 10ms
D/dalvikvm( 2339): GC_EXPLICIT freed 19K, 2% free 1679K/1700K, paused 1ms+1ms, t        otal 10ms
D/dalvikvm( 2339): GC_EXPLICIT freed 23K, 2% free 1710K/1740K, paused 1ms+2ms, t        otal 11ms
D/dalvikvm( 2339): GC_EXPLICIT freed 29K, 2% free 1736K/1768K, paused 1ms+1ms, t        otal 11ms
D/dalvikvm( 2339): GC_FOR_ALLOC freed 252K, 12% free 1997K/2252K, paused 13ms, t        otal 13ms
D/dalvikvm( 2339): GC_EXPLICIT freed 207K, 10% free 2117K/2332K, paused 1ms+2ms,        total 14ms
D/dalvikvm( 2339): GC_EXPLICIT freed 35K, 9% free 2136K/2332K, paused 1ms+1ms, t        otal 14ms
D/dalvikvm( 2339): GC_EXPLICIT freed 25K, 8% free 2169K/2340K, paused 1ms+1ms, t        otal 14ms
W/Zygote  ( 2339): Class not found for preloading: java.lang.UnsafeByteSequence
D/dalvikvm( 2339): GC_EXPLICIT freed 36K, 7% free 2189K/2340K, paused 1ms+1ms, t        otal 14ms
D/dalvikvm( 2339): GC_EXPLICIT freed 41K, 6% free 2206K/2340K, paused 1ms+1ms, t        otal 14ms
D/dalvikvm( 2339): GC_EXPLICIT freed 42K, 6% free 2219K/2340K, paused 1ms+1ms, t        otal 15ms
I/System  ( 2339): Loaded time zone names for "" in 81ms (75ms in ICU)
I/System  ( 2339): Loaded time zone names for "en_US" in 51ms (45ms in ICU)
D/dalvikvm( 2339): GC_EXPLICIT freed 193K, 9% free 2383K/2596K, paused 1ms+1ms,        total 15ms
D/dalvikvm( 2339): GC_EXPLICIT freed 14K, 6% free 2447K/2596K, paused 1ms+1ms, t        otal 15ms
D/dalvikvm( 2339): GC_EXPLICIT freed 30K, 5% free 2473K/2596K, paused 1ms+2ms, t        otal 15ms
D/dalvikvm( 2339): GC_EXPLICIT freed 34K, 4% free 2493K/2596K, paused 1ms+2ms, t        otal 15ms
D/dalvikvm( 2339): GC_EXPLICIT freed 32K, 4% free 2514K/2596K, paused 1ms+2ms, t        otal 16ms
D/dalvikvm( 2339): GC_EXPLICIT freed 29K, 3% free 2540K/2600K, paused 2ms+1ms, t        otal 16ms
I/Zygote  ( 2339): ...preloaded 2777 classes in 3074ms.
D/dalvikvm( 2339): GC_EXPLICIT freed 17K, 3% free 2543K/2600K, paused 1ms+2ms, t        otal 16ms
I/Zygote  ( 2339): Preloading resources...
W/Resources( 2339): Preloaded drawable resource #0x1080096 (android:drawable/toa        st_frame) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080105 (android:drawable/btn        _check_on_pressed_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080104 (android:drawable/btn        _check_on_pressed_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080102 (android:drawable/btn        _check_on_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080101 (android:drawable/btn        _check_on_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800ff (android:drawable/btn        _check_on_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800fe (android:drawable/btn        _check_on_focused_holo_dark) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 34K, 3% free 2563K/2636K, paused 1ms+2ms, t        otal 16ms
W/Resources( 2339): Preloaded drawable resource #0x10800fd (android:drawable/btn        _check_on_disabled_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800fc (android:drawable/btn        _check_on_disabled_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800fb (android:drawable/btn        _check_on_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800fa (android:drawable/btn        _check_on_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800f2 (android:drawable/btn        _check_off_pressed_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800f1 (android:drawable/btn        _check_off_pressed_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800ed (android:drawable/btn        _check_off_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800ec (android:drawable/btn        _check_off_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800ea (android:drawable/btn        _check_off_focused_holo_light) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 59K, 4% free 2556K/2644K, paused 1ms+1ms, t        otal 16ms
W/Resources( 2339): Preloaded drawable resource #0x10800e9 (android:drawable/btn        _check_off_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800e8 (android:drawable/btn        _check_off_disabled_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800e7 (android:drawable/btn        _check_off_disabled_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800e6 (android:drawable/btn        _check_off_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800e5 (android:drawable/btn        _check_off_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800dc (android:drawable/btn        _check_holo_light) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 108K, 5% free 2560K/2688K, paused 1ms+1ms,        total 16ms
W/Resources( 2339): Preloaded drawable resource #0x10800db (android:drawable/btn        _check_holo_dark) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 84K, 5% free 2559K/2688K, paused 1ms+1ms, t        otal 16ms
W/Resources( 2339): Preloaded drawable resource #0x1080195 (android:drawable/btn        _radio_on_pressed_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080194 (android:drawable/btn        _radio_on_pressed_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080192 (android:drawable/btn        _radio_on_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080191 (android:drawable/btn        _radio_on_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108018f (android:drawable/btn        _radio_on_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108018e (android:drawable/btn        _radio_on_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108018d (android:drawable/btn        _radio_on_disabled_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108018c (android:drawable/btn        _radio_on_disabled_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108018b (android:drawable/btn        _radio_on_disabled_focused_holo_light) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 53K, 5% free 2559K/2688K, paused 2ms+2ms, t        otal 16ms
W/Resources( 2339): Preloaded drawable resource #0x108018a (android:drawable/btn        _radio_on_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080187 (android:drawable/btn        _radio_off_pressed_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080186 (android:drawable/btn        _radio_off_pressed_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080184 (android:drawable/btn        _radio_off_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080183 (android:drawable/btn        _radio_off_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080181 (android:drawable/btn        _radio_off_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080180 (android:drawable/btn        _radio_off_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108017f (android:drawable/btn        _radio_off_disabled_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108017e (android:drawable/btn        _radio_off_disabled_holo_dark) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 51K, 5% free 2561K/2688K, paused 1ms+1ms, t        otal 16ms
W/Resources( 2339): Preloaded drawable resource #0x108017d (android:drawable/btn        _radio_off_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108017c (android:drawable/btn        _radio_off_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080128 (android:drawable/btn        _default_pressed_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080127 (android:drawable/btn        _default_pressed_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080124 (android:drawable/btn        _default_normal_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080123 (android:drawable/btn        _default_normal_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108011c (android:drawable/btn        _default_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108011b (android:drawable/btn        _default_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080119 (android:drawable/btn        _default_disabled_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080118 (android:drawable/btn        _default_disabled_holo_dark) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 24K, 4% free 2590K/2688K, paused 1ms+1ms, t        otal 18ms
W/Resources( 2339): Preloaded drawable resource #0x1080116 (android:drawable/btn        _default_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080115 (android:drawable/btn        _default_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108011d (android:drawable/btn        _default_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108011e (android:drawable/btn        _default_holo_light) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 55K, 3% free 2621K/2692K, paused 1ms+2ms, t        otal 16ms
W/Resources( 2339): Preloaded drawable resource #0x10801d1 (android:drawable/btn        _star_off_normal_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801db (android:drawable/btn        _star_on_normal_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801d7 (android:drawable/btn        _star_on_disabled_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801cd (android:drawable/btn        _star_off_disabled_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801dd (android:drawable/btn        _star_on_pressed_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801d3 (android:drawable/btn        _star_off_pressed_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801d9 (android:drawable/btn        _star_on_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801cf (android:drawable/btn        _star_off_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801d5 (android:drawable/btn        _star_on_disabled_focused_holo_light) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 108K, 6% free 2566K/2708K, paused 1ms+2ms,        total 21ms
W/Resources( 2339): Preloaded drawable resource #0x10801cb (android:drawable/btn        _star_off_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801c8 (android:drawable/btn        _star_holo_light) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 86K, 6% free 2568K/2708K, paused 1ms+2ms, t        otal 16ms
W/Resources( 2339): Preloaded drawable resource #0x10801d0 (android:drawable/btn        _star_off_normal_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801da (android:drawable/btn        _star_on_normal_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801d6 (android:drawable/btn        _star_on_disabled_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801cc (android:drawable/btn        _star_off_disabled_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801dc (android:drawable/btn        _star_on_pressed_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801d2 (android:drawable/btn        _star_off_pressed_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801d8 (android:drawable/btn        _star_on_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801ce (android:drawable/btn        _star_off_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801d4 (android:drawable/btn        _star_on_disabled_focused_holo_dark) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 53K, 6% free 2567K/2708K, paused 1ms+2ms, t        otal 16ms
W/Resources( 2339): Preloaded drawable resource #0x10801ca (android:drawable/btn        _star_off_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801c7 (android:drawable/btn        _star_holo_dark) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 86K, 6% free 2570K/2708K, paused 1ms+2ms, t        otal 16ms
W/Resources( 2339): Preloaded drawable resource #0x10801f7 (android:drawable/btn        _toggle_on_pressed_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801f6 (android:drawable/btn        _toggle_on_pressed_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801f5 (android:drawable/btn        _toggle_on_normal_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801f4 (android:drawable/btn        _toggle_on_normal_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801f3 (android:drawable/btn        _toggle_on_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801f2 (android:drawable/btn        _toggle_on_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801f1 (android:drawable/btn        _toggle_on_disabled_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801f0 (android:drawable/btn        _toggle_on_disabled_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801ef (android:drawable/btn        _toggle_on_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801ee (android:drawable/btn        _toggle_on_disabled_focused_holo_dark) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 18K, 4% free 2605K/2708K, paused 2ms+2ms, t        otal 17ms
W/Resources( 2339): Preloaded drawable resource #0x10801ec (android:drawable/btn        _toggle_off_pressed_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801eb (android:drawable/btn        _toggle_off_pressed_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801ea (android:drawable/btn        _toggle_off_normal_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801e9 (android:drawable/btn        _toggle_off_normal_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801e8 (android:drawable/btn        _toggle_off_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801e7 (android:drawable/btn        _toggle_off_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801e6 (android:drawable/btn        _toggle_off_disabled_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801e5 (android:drawable/btn        _toggle_off_disabled_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801e4 (android:drawable/btn        _toggle_off_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10801e3 (android:drawable/btn        _toggle_off_disabled_focused_holo_dark) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 51K, 4% free 2606K/2708K, paused 1ms+1ms, t        otal 16ms
W/Resources( 2339): Preloaded drawable resource #0x10801e1 (android:drawable/btn        _toggle_holo_light) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 59K, 4% free 2622K/2708K, paused 1ms+2ms, t        otal 16ms
W/Resources( 2339): Preloaded drawable resource #0x10801e0 (android:drawable/btn        _toggle_holo_dark) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 75K, 4% free 2622K/2716K, paused 1ms+2ms, t        otal 17ms
W/Resources( 2339): Preloaded drawable resource #0x108064c (android:drawable/tex        tfield_multiline_default_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080650 (android:drawable/tex        tfield_multiline_disabled_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108064a (android:drawable/tex        tfield_multiline_activated_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080652 (android:drawable/tex        tfield_multiline_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108064e (android:drawable/tex        tfield_multiline_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108063f (android:drawable/tex        tfield_default_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080644 (android:drawable/tex        tfield_disabled_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080637 (android:drawable/tex        tfield_activated_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080647 (android:drawable/tex        tfield_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080642 (android:drawable/tex        tfield_disabled_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080258 (android:drawable/edi        t_text_holo_light) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 75K, 4% free 2623K/2716K, paused 2ms+1ms, t        otal 17ms
W/Resources( 2339): Preloaded drawable resource #0x108064b (android:drawable/tex        tfield_multiline_default_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108064f (android:drawable/tex        tfield_multiline_disabled_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080649 (android:drawable/tex        tfield_multiline_activated_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080651 (android:drawable/tex        tfield_multiline_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108064d (android:drawable/tex        tfield_multiline_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108063e (android:drawable/tex        tfield_default_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080643 (android:drawable/tex        tfield_disabled_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080636 (android:drawable/tex        tfield_activated_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080646 (android:drawable/tex        tfield_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080641 (android:drawable/tex        tfield_disabled_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080257 (android:drawable/edi        t_text_holo_dark) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 74K, 4% free 2625K/2716K, paused 2ms+1ms, t        otal 17ms
W/Resources( 2339): Preloaded drawable resource #0x1080633 (android:drawable/tex        t_select_handle_left) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080635 (android:drawable/tex        t_select_handle_right) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080630 (android:drawable/tex        t_edit_paste_window) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108026d (android:drawable/exp        ander_close_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108026e (android:drawable/exp        ander_close_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080274 (android:drawable/exp        ander_open_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080270 (android:drawable/exp        ander_group_holo_dark) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 85K, 5% free 2598K/2728K, paused 1ms+1ms, t        otal 17ms
W/Resources( 2339): Preloaded drawable resource #0x1080275 (android:drawable/exp        ander_open_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080271 (android:drawable/exp        ander_group_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108041d (android:drawable/lis        t_selector_disabled_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10803fe (android:drawable/lis        t_pressed_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10803fc (android:drawable/lis        t_longpressed_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108041a (android:drawable/lis        t_selector_background_transition_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10803f7 (android:drawable/lis        t_focused_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080421 (android:drawable/lis        t_selector_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108041e (android:drawable/lis        t_selector_disabled_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10803ff (android:drawable/lis        t_pressed_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10803fd (android:drawable/lis        t_longpressed_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108041b (android:drawable/lis        t_selector_background_transition_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080422 (android:drawable/lis        t_selector_holo_light) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 54K, 5% free 2604K/2728K, paused 2ms+1ms, t        otal 17ms
W/Resources( 2339): Preloaded drawable resource #0x1080401 (android:drawable/lis        t_section_divider_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080400 (android:drawable/lis        t_section_divider_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080432 (android:drawable/men        u_hardkey_panel_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080433 (android:drawable/men        u_hardkey_panel_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108043a (android:drawable/men        u_submenu_background) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080431 (android:drawable/men        u_dropdown_panel_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080430 (android:drawable/men        u_dropdown_panel_holo_dark) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 35K, 4% free 2621K/2728K, paused 2ms+1ms, t        otal 16ms
W/Resources( 2339): Preloaded drawable resource #0x1080437 (android:drawable/men        u_popup_panel_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080436 (android:drawable/men        u_popup_panel_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080435 (android:drawable/men        u_panel_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080434 (android:drawable/men        u_panel_holo_dark) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 53K, 5% free 2631K/2764K, paused 1ms+2ms, t        otal 16ms
W/Resources( 2339): Preloaded drawable resource #0x108047c (android:drawable/ove        rscroll_edge) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108047d (android:drawable/ove        rscroll_glow) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 354K, 16% free 2581K/3040K, paused 1ms+1ms,        total 17ms
W/Resources( 2339): Preloaded drawable resource #0x1080545 (android:drawable/spi        nner_16_outer_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080544 (android:drawable/spi        nner_16_inner_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080549 (android:drawable/spi        nner_48_outer_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080548 (android:drawable/spi        nner_48_inner_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108054b (android:drawable/spi        nner_76_outer_holo) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 49K, 16% free 2582K/3040K, paused 1ms+2ms,        total 16ms
W/Resources( 2339): Preloaded drawable resource #0x108054a (android:drawable/spi        nner_76_inner_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10804c5 (android:drawable/pro        gress_bg_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10804c6 (android:drawable/pro        gress_bg_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10804d2 (android:drawable/pro        gress_secondary_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10804d0 (android:drawable/pro        gress_primary_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10804c7 (android:drawable/pro        gress_horizontal_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10804d3 (android:drawable/pro        gress_secondary_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10804d1 (android:drawable/pro        gress_primary_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10804c8 (android:drawable/pro        gress_horizontal_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10804db (android:drawable/pro        gressbar_indeterminate_holo1) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10804dc (android:drawable/pro        gressbar_indeterminate_holo2) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10804dd (android:drawable/pro        gressbar_indeterminate_holo3) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10804de (android:drawable/pro        gressbar_indeterminate_holo4) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10804df (android:drawable/pro        gressbar_indeterminate_holo5) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10804e0 (android:drawable/pro        gressbar_indeterminate_holo6) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10804e1 (android:drawable/pro        gressbar_indeterminate_holo7) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10804e2 (android:drawable/pro        gressbar_indeterminate_holo8) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10804c9 (android:drawable/pro        gress_indeterminate_horizontal_holo) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 355K, 15% free 2595K/3040K, paused 1ms+2ms,        total 16ms
W/Resources( 2339): Preloaded drawable resource #0x10804cb (android:drawable/pro        gress_large_holo) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 60K, 15% free 2585K/3040K, paused 1ms+1ms,        total 17ms
W/Resources( 2339): Preloaded drawable resource #0x10804ce (android:drawable/pro        gress_medium_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10804d5 (android:drawable/pro        gress_small_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080535 (android:drawable/scr        ubber_track_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080534 (android:drawable/scr        ubber_secondary_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080531 (android:drawable/scr        ubber_primary_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080532 (android:drawable/scr        ubber_progress_horizontal_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080536 (android:drawable/scr        ubber_track_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080533 (android:drawable/scr        ubber_progress_horizontal_holo_light) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 46K, 15% free 2599K/3040K, paused 2ms+1ms,        total 18ms
W/Resources( 2339): Preloaded drawable resource #0x1080528 (android:drawable/scr        ollbar_handle_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080529 (android:drawable/scr        ollbar_handle_holo_light) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 19K, 14% free 2632K/3040K, paused 1ms+2ms,        total 16ms
W/Resources( 2339): Preloaded drawable resource #0x1080208 (android:drawable/cab        _background_bottom_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108020b (android:drawable/cab        _background_top_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080209 (android:drawable/cab        _background_bottom_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10802bc (android:drawable/ic_        cab_done_holo_dark) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 21K, 13% free 2662K/3040K, paused 1ms+2ms,        total 16ms
W/Resources( 2339): Preloaded drawable resource #0x108020a (android:drawable/cab        _background_top_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10802bd (android:drawable/ic_        cab_done_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800d0 (android:drawable/btn        _cab_done_default_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800d3 (android:drawable/btn        _cab_done_focused_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800d1 (android:drawable/btn        _cab_done_default_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800d6 (android:drawable/btn        _cab_done_pressed_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800d2 (android:drawable/btn        _cab_done_focused_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800d7 (android:drawable/btn        _cab_done_pressed_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800d5 (android:drawable/btn        _cab_done_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800d4 (android:drawable/btn        _cab_done_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080038 (android:drawable/ic_        menu_close_clear_cancel) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108033e (android:drawable/ic_        menu_copy_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108033f (android:drawable/ic_        menu_copy_holo_light) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 53K, 13% free 2665K/3040K, paused 2ms+2ms,        total 18ms
W/Resources( 2339): Preloaded drawable resource #0x1080341 (android:drawable/ic_        menu_cut_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080342 (android:drawable/ic_        menu_cut_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080045 (android:drawable/ic_        menu_more) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080355 (android:drawable/ic_        menu_moreoverflow_normal_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080353 (android:drawable/ic_        menu_moreoverflow_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080356 (android:drawable/ic_        menu_moreoverflow_normal_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080354 (android:drawable/ic_        menu_moreoverflow_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080359 (android:drawable/ic_        menu_paste_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108035a (android:drawable/ic_        menu_paste_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080360 (android:drawable/ic_        menu_selectall_holo_light) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 60K, 13% free 2659K/3040K, paused 1ms+2ms,        total 16ms
W/Resources( 2339): Preloaded drawable resource #0x108035f (android:drawable/ic_        menu_selectall_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10802c0 (android:drawable/ic_        clear_disabled) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10802c2 (android:drawable/ic_        clear_normal) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10802bf (android:drawable/ic_        clear) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080392 (android:drawable/ic_        search) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10802dd (android:drawable/ic_        go) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108039b (android:drawable/ic_        voice_search) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080221 (android:drawable/dia        log_bottom_holo_dark) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 48K, 13% free 2669K/3040K, paused 1ms+1ms,        total 17ms
W/Resources( 2339): Preloaded drawable resource #0x1080222 (android:drawable/dia        log_bottom_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080226 (android:drawable/dia        log_full_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080227 (android:drawable/dia        log_full_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108022f (android:drawable/dia        log_middle_holo_dark) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 16K, 12% free 2704K/3040K, paused 1ms+1ms,        total 17ms
W/Resources( 2339): Preloaded drawable resource #0x1080230 (android:drawable/dia        log_middle_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080231 (android:drawable/dia        log_top_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080232 (android:drawable/dia        log_top_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10802d1 (android:drawable/ic_        dialog_alert_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10802d2 (android:drawable/ic_        dialog_alert_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10803f4 (android:drawable/lis        t_divider_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10803f5 (android:drawable/lis        t_divider_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800bd (android:drawable/ab_        transparent_dark_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800bb (android:drawable/ab_        stacked_transparent_dark_holo) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 66K, 12% free 2690K/3040K, paused 1ms+1ms,        total 17ms
W/Resources( 2339): Preloaded drawable resource #0x10800a1 (android:drawable/ab_        bottom_transparent_dark_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800b5 (android:drawable/ab_        solid_dark_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800b8 (android:drawable/ab_        stacked_solid_dark_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108009e (android:drawable/ab_        bottom_solid_dark_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800be (android:drawable/ab_        transparent_light_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800bc (android:drawable/ab_        stacked_transparent_light_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800a2 (android:drawable/ab_        bottom_transparent_light_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800b6 (android:drawable/ab_        solid_light_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800ba (android:drawable/ab_        stacked_solid_light_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800a0 (android:drawable/ab_        bottom_solid_light_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10800b7 (android:drawable/ab_        solid_shadow_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x10803b3 (android:drawable/ite        m_background_holo_dark) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 58K, 12% free 2697K/3040K, paused 1ms+2ms,        total 16ms
W/Resources( 2339): Preloaded drawable resource #0x10803b4 (android:drawable/ite        m_background_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108027c (android:drawable/fas        tscroll_thumb_pressed_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108027a (android:drawable/fas        tscroll_thumb_default_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108027b (android:drawable/fas        tscroll_thumb_holo) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 83K, 13% free 2672K/3040K, paused 1ms+2ms,        total 16ms
W/Resources( 2339): Preloaded drawable resource #0x1080281 (android:drawable/fas        tscroll_track_pressed_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108027d (android:drawable/fas        tscroll_track_default_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108027f (android:drawable/fas        tscroll_track_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080276 (android:drawable/fas        tscroll_label_left_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080278 (android:drawable/fas        tscroll_label_right_holo_dark) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 19K, 11% free 2707K/3040K, paused 1ms+1ms,        total 18ms
W/Resources( 2339): Preloaded drawable resource #0x1080282 (android:drawable/fas        tscroll_track_pressed_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108027e (android:drawable/fas        tscroll_track_default_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080280 (android:drawable/fas        tscroll_track_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080277 (android:drawable/fas        tscroll_label_left_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080279 (android:drawable/fastscroll_label_right_holo_light) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 54K, 11% free 2708K/3040K, paused 2ms+2ms, total 17ms
W/Resources( 2339): Preloaded drawable resource #0x108025b (android:drawable/editbox_dropdown_background_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080662 (android:drawable/textfield_search_selected_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080656 (android:drawable/textfield_search_default_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080664 (android:drawable/textfield_searchview_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108065f (android:drawable/textfield_search_right_selected_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108065d (android:drawable/textfield_search_right_default_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080666 (android:drawable/textfield_searchview_right_holo_dark) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080663 (android:drawable/textfield_search_selected_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080657 (android:drawable/textfield_search_default_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080665 (android:drawable/textfield_searchview_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080660 (android:drawable/textfield_search_right_selected_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108065e (android:drawable/textfield_search_right_default_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080667 (android:drawable/textfield_searchview_right_holo_light) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108062b (android:drawable/tab_unselected_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080626 (android:drawable/tab_selected_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108062a (android:drawable/tab_unselected_focused_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080625 (android:drawable/tab_selected_focused_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108062c (android:drawable/tab_unselected_pressed_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x1080627 (android:drawable/tab_selected_pressed_holo) that varies with configuration!!
W/Resources( 2339): Preloaded drawable resource #0x108061a (android:drawable/tab_indicator_holo) that varies with configuration!!
D/dalvikvm( 2339): GC_EXPLICIT freed 86K, 12% free 2685K/3040K, paused 1ms+2ms, total 16ms
I/Zygote  ( 2339): ...preloaded 274 resources in 1038ms.
D/dalvikvm( 2339): GC_EXPLICIT freed 35K, 12% free 2704K/3040K, paused 2ms+2ms, total 19ms
I/Zygote  ( 2339): ...preloaded 31 resources in 28ms.
D/dalvikvm( 2339): GC_EXPLICIT freed 15K, 12% free 2698K/3040K, paused 1ms+1ms, total 17ms
D/dalvikvm( 2339): GC_EXPLICIT freed 4K, 12% free 2694K/3040K, paused 2ms+2ms, total 17ms
D/dalvikvm( 2339): GC_EXPLICIT freed <1K, 12% free 2694K/3040K, paused 2ms+1ms, total 17ms
I/dalvikvm( 2339): System server process 2703 has been created
I/Zygote  ( 2339): Accepting command socket connections
D/        ( 2703): Setting time of day to sec=86400
W/SystemServer( 2703): System clock is before 1970; setting to 1970.
D/SensorService( 2703): nuSensorService starting...
I/SystemServer( 2703): Entered the Android system server!
I/v_hwc   ( 2338): vsync thread exit: callback procs not registered.
E/        ( 2703): couldn't find 'isl29023 light sensor' input device
D/        ( 2703): AccelSensor enable 0 , handle 0 ,mEnabled 0
D/        ( 2703): AccelSensor enable 0 , handle 1 ,mEnabled 0
D/        ( 2703): MagSensor mEnabled 0, OrientaionSensor mEnabled 0
D/        ( 2703): AccelSensor enable 0 , handle 2 ,mEnabled 0
I/SensorService( 2703): Freescale 3-axis Accelerometer
I/SensorService( 2703): Freescale 3-axis Magnetic field sensor
I/SensorService( 2703): Freescale Orientation sensor
I/SensorService( 2703): ISL29023 Light sensor
D/SensorService( 2703): Max socket buffer size 131071
D/SensorService( 2703): nuSensorService thread starting...
I/installd( 2342): new connection
E/SWITCHPROFILE( 2703): setprop: sys.interactive = active
I/SystemServer( 2703): Waiting for installd to be ready.
I/Installer( 2703): connecting...
I/SystemServer( 2703): Power Manager
I/SystemServer( 2703): Activity Manager
I/ActivityManager( 2703): Memory class: 64
D/dalvikvm( 2703): GC_CONCURRENT freed 194K, 8% free 2952K/3208K, paused 3ms+1ms, total 19ms
I/IntentFirewall( 2703): Read new rules (A:0 B:0 S:0)
I/SystemServer( 2703): Display Manager
I/SystemServer( 2703): Telephony Registry
I/SystemServer( 2703): Scheduling Policy
I/DisplayManagerService( 2703): Display device added: DisplayDeviceInfo{"Built-in Screen": 1024 x 768, 60.000004 fps, density 160, 213.0 x 213.0 dpi, touch INTERNAL, rotation 0, type BUILT_IN, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/SystemServer( 2703): Package Manager
D/dalvikvm( 2703): GC_CONCURRENT freed 397K, 14% free 3058K/3528K, paused 1ms+2ms, total 14ms
D/dalvikvm( 2703): WAIT_FOR_CONCURRENT_GC blocked 7ms
D/SELinuxMMAC( 2703): Couldn't find install policy /data/security/mac_permissions.xml
D/SELinuxMMAC( 2703): Using install policy file /system/etc/security/mac_permissions.xml
D/dalvikvm( 2703): GC_CONCURRENT freed 330K, 12% free 3156K/3552K, paused 3ms+3ms, total 17ms
D/dalvikvm( 2703): GC_CONCURRENT freed 221K, 8% free 3387K/3672K, paused 3ms+2ms, total 19ms
W/PackageParser( 2703): No actions in intent filter at /system/priv-app/Contacts.apk Binary XML file line #375
W/PackageParser( 2703): No actions in intent filter at /system/priv-app/Dialer.apk Binary XML file line #162
W/ResourceType( 2703): Failure getting entry for 0x7f050000 (t=4 e=0) in package 0 (error -75)
I/AudioFlinger( 2341): Using module 1 has the primary audio interface
I/AudioFlinger( 2341): AudioFlinger's thread 0x40cc4008 ready to run
W/audio_hw_primary( 2341): out_set_parameters routing=2, ret 1, out 1074472776
I/audio_a2dp_hw( 2341): adev_open:  adev_open in A2dp_hw module
I/AudioFlinger( 2341): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 3
W/Binder  ( 2703): Caught a RuntimeException from the binder stub implementation.
W/Binder  ( 2703): java.lang.NullPointerException
W/Binder  ( 2703):      at com.android.server.power.PowerManagerService.updateWakeLockWorkSource(PowerManagerService.java:770)
W/Binder  ( 2703):      at com.android.server.power.PowerManagerService.updateWakeLockUids(PowerManagerService.java:761)
W/Binder  ( 2703):      at android.os.IPowerManager$Stub.onTransact(IPowerManager.java:103)
W/Binder  ( 2703):      at android.os.Binder.execTransact(Binder.java:404)
W/Binder  ( 2703):      at dalvik.system.NativeStart.run(Native Method)
I/r_submix( 2341): adev_open(name=audio_hw_if)
I/r_submix( 2341): adev_init_check()
I/AudioFlinger( 2341): loadHwModule() Loaded r_submix audio interface from Wifi Display audio HAL (audio) handle 4
I/AudioFlinger( 2341): loadHwModule() Loaded usb audio interface from USB audio HW HAL (audio) handle 5
I/AudioPolicyService( 2341): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
D/dalvikvm( 2703): GC_CONCURRENT freed 148K, 6% free 3665K/3876K, paused 3ms+3ms, total 24ms
W/PackageParser( 2703): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #210
D/dalvikvm( 2703): GC_CONCURRENT freed 249K, 8% free 3835K/4148K, paused 1ms+2ms, total 21ms
W/ResourceType( 2703): Failure getting entry for 0x7f04000f (t=3 e=15) in package 0 (error -75)
W/PackageParser( 2703): Unknown element under <application>: permission at /system/app/Gallery2.apk Binary XML file line #257
W/PackageParser( 2703): Unknown element under <application>: permission at /system/app/Gallery2.apk Binary XML file line #260
D/dalvikvm( 2703): GC_CONCURRENT freed 227K, 7% free 4016K/4308K, paused 2ms+2ms, total 23ms
D/PackageManager( 2703): No files in app dir /vendor/app
W/PackageManager( 2703): Package com.android.gallery3d desires unavailable shared library com.google.android.media.effects; ignoring!
I/PackageManager( 2703): Time to scan packages: 1.925 seconds
W/PackageManager( 2703): Not granting permission android.permission.GLOBAL_SEARCH to package com.android.quicksearchbox (protectionLevel=18 flags=0x8be45)
W/PackageManager( 2703): Unknown permission com.android.smspush.WAPPUSH_MANAGER_BIND in package com.android.phone
W/PackageManager( 2703): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
W/PackageManager( 2703): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager( 2703): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager( 2703): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
W/PackageManager( 2703): Not granting permission android.permission.ACCESS_DOWNLOAD_MANAGER to package com.android.browser (protectionLevel=18 flags=0x9be45)
W/PackageManager( 2703): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
W/PackageManager( 2703): Not granting permission android.permission.BIND_WALLPAPER to package com.android.camera2 (protectionLevel=18 flags=0x58bc45)
W/PackageManager( 2703): Unknown permission android.permission.INSTALL_DRM in package com.android.mms
W/PackageManager( 2703): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager( 2703): Not granting permission android.permission.WRITE_MEDIA_STORAGE to package com.android.gallery3d (protectionLevel=18 flags=0x58bc45)
W/PackageManager( 2703): Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x8be45)
W/PackageManager( 2703): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x48be45)
D/dalvikvm( 2703): GC_CONCURRENT freed 351K, 10% free 4088K/4504K, paused 3ms+2ms, total 24ms
D/dalvikvm( 2703): GC_EXPLICIT freed 175K, 12% free 3981K/4516K, paused 2ms+2ms, total 29ms
I/SystemServer( 2703): Entropy Mixer
I/EntropyMixer( 2703): Writing entropy...
I/SystemServer( 2703): User Service
I/SystemServer( 2703): Account Manager
I/SystemServer( 2703): Content Manager
I/SystemServer( 2703): System Content Providers
I/SystemServer( 2703): Lights Service
I/lights  ( 2703): max backlight file is /sys/class/backlight/pwm-backlight.0/max_brightness
I/lights  ( 2703): backlight brightness file is /sys/class/backlight/pwm-backlight.0/brightness
I/SystemServer( 2703): Battery Service
I/SystemServer( 2703): Vibrator Service
I/SystemServer( 2703): Consumer IR Service
I/libsuspend( 2703): Selected early suspend
I/libsuspend( 2703): Starting early suspend unblocker thread
I/SWITCHPROFILE( 2703): Switchprofile thread received GOV_INTERACTIVE from Power HAL
D/PermissionCache( 2338): checking android.permission.ACCESS_SURFACE_FLINGER for uid=1000 => granted (316 us)
D/SurfaceFlinger( 2338): Screen acquired, type=0 flinger=0x41e03450
D/SurfaceFlinger( 2338):  screen was previously acquired
I/SystemServer( 2703): Alarm Manager
I/SystemServer( 2703): Init Watchdog
I/SystemServer( 2703): Input Manager
I/InputManager( 2703): Initializing input manager, mUseDevInputEventForAudioJack=false
I/SystemServer( 2703): Window Manager
I/WindowManager( 2703): No existing display settings /data/system/display_settings.xml; starting empty
D/        ( 2703): AccelSensor enable 1 , handle 0 ,mEnabled 1
D/EventHub( 2703): No input device configuration file found for device 'FreescaleAccelerometer'.
D/BluetoothManagerService( 2703): Loading stored name and address
D/BluetoothManagerService( 2703): Stored bluetooth Name=iMX6,Address=22:22:7F:8E:05:9D
I/WindowManager( 2703): No keyguard interface!
I/InputManager( 2703): Starting input manager
I/SystemServer( 2703): Bluetooth Manager Service
I/SystemServer( 2703): Input Method Service
W/InputMethodManagerService( 2703): Couldn't create dir.: /data/system/inputmethod
W/ResourceType( 2703): Failure getting entry for 0x7f060000 (t=5 e=0) in package 0 (error -75)
I/SystemServer( 2703): Accessibility Manager
I/ActivityManager( 2703): Config changes=1df8 {1.0 ?mcc?mnc en_US ldltr sw768dp w1024dp h768dp 160dpi xlrg land ?uimode ?night -touch -keyb/v/h -nav/h s.2}
D/EventHub( 2703): No input device configuration file found for device 'eCompass'.
D/dalvikvm( 2703): GC_CONCURRENT freed 215K, 8% free 4190K/4516K, paused 3ms+2ms, total 28ms
I/ActivityManager( 2703): Config changes=400 {1.0 ?mcc?mnc en_US ldltr sw768dp w1024dp h695dp 160dpi xlrg land ?uimode ?night -touch -keyb/v/h -nav/h s.3}
I/SystemServer( 2703): Mount Service
D/MountService( 2703): got storage path: null description: Internal storage primary: true removable: false emulated: true mtpReserve: 100 allowMassStorage: false maxFileSize: 0
D/MountService( 2703): addVolumeLocked() StorageVolume:
D/MountService( 2703):     mStorageId=65537 mPath=/storage/emulated/0 mDescriptionId=17040662
D/MountService( 2703):     mPrimary=true mRemovable=false mEmulated=true mMtpReserveSpace=100
D/MountService( 2703):     mAllowMassStorage=false mMaxFileSize=0 mOwner=UserHandle{0} mUuid=null
D/MountService( 2703):     mUserLabel=null mState=null
D/MountService( 2703): got storage path: /storage/extsd description: SD card primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 0
D/MountService( 2703):     mStorageId=0 mPath=/storage/extsd mDescriptionId=17040663 mPrimary=false
D/MountService( 2703):     mRemovable=true mEmulated=false mMtpReserveSpace=0 mAllowMassStorage=false
D/MountService( 2703):     mMaxFileSize=0 mOwner=null mUuid=null mUserLabel=null mState=null
D/MountService( 2703): got storage path: /storage/udisk description: USB storage primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 0
D/MountService( 2703):     mStorageId=0 mPath=/storage/udisk mDescriptionId=17040664 mPrimary=false
I/SystemServer( 2703): LockSettingsService
I/SystemServer( 2703): Device Policy
I/SystemServer( 2703): Status Bar
I/SystemServer( 2703): Clipboard Service
I/SystemServer( 2703): NetworkManagement Service
D/MountService( 2703): volume state changed for /storage/extsd (unmounted -> removed)
D/MountService( 2703): volume state changed for /storage/udisk (unmounted -> removed)
I/SystemServer( 2703): Text Service Manager Service
I/PackageManager( 2703): No secure containers on sdcard
D/EventHub( 2703): No input device configuration file found for device 'FreescaleMagnetometer'.
E/EventHub( 2703): could not get driver version for /dev/input/mice, Not a typewriter
I/SystemServer( 2703): NetworkStats Service
I/SystemServer( 2703): NetworkPolicy Service
I/SystemServer( 2703): Wi-Fi P2pService
D/dalvikvm( 2703): GC_CONCURRENT freed 320K, 9% free 4267K/4660K, paused 3ms+6ms, total 29ms
I/SystemServer( 2703): Wi-Fi Service
I/SystemServer( 2703): Connectivity Service
D/ConnectivityService( 2703): ConnectivityService starting up
D/ConnectivityService( 2703): wifiOnly=false
E/ConnectivityService( 2703): Ignoring protectedNetwork 14
D/EventHub( 2703): No input device configuration file found for device 'wm8962-audio Headphone Jack'.
I/EventHub( 2703): New device: id=4, fd=120, path='/dev/input/event8', name='wm8962-audio Headphone Jack', classes=0x80, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false, usingSuspendBlockIoctl=true, usingClockIoctl=false
D/EventHub( 2703): No input device configuration file found for device 'wm8962-audio DMIC'.
I/EventHub( 2703): New device: id=5, fd=121, path='/dev/input/event7', name='wm8962-audio DMIC', classes=0x80, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false, usingSuspendBlockIoctl=true, usingClockIoctl=false
D/EventHub( 2703): No input device configuration file found for device 'Logitech USB Optical Mouse'.
I/EventHub( 2703): New device: id=6, fd=122, path='/dev/input/event5', name='Logitech USB Optical Mouse', classes=0x80000008, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false, usingSuspendBlockIoctl=true, usingClockIoctl=false
E/EventHub( 2703): could not get driver version for /dev/input/mouse1, Not a typewriter
D/CommandListener( 2336): Setting iface cfg
D/CommandListener( 2336): Trying to bring up eth0
D/WifiHW  ( 2703): Unable to unload driver module "8723as": No such file or directory
D/EventHub( 2703): No input device configuration file found for device 'gpio-keys'.
W/EventHub( 2703): Unable to disable kernel key repeat for /dev/input/event0: Function not implemented
I/EventHub( 2703): New device: id=7, fd=123, path='/dev/input/event0', name='gpio-keys', classes=0x1, configuration='', keyLayout='/system/usr/keylayout/Generic.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', builtinKeyboard=false, usingSuspendBlockIoctl=true, usingClockIoctl=false
D/EventHub( 2703): No input device configuration file found for device 'max11801_ts'.
I/EventHub( 2703): New device: id=8, fd=124, path='/dev/input/event1', name='max11801_ts', classes=0x4, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false, usingSuspendBlockIoctl=true, usingClockIoctl=false
E/EventHub( 2703): could not get driver version for /dev/input/mouse0, Not a typewriter
D/BluetoothTethering( 2703): startMonitoring: target: Handler (com.android.server.ConnectivityService$NetworkStateTrackerHandler) {41f55b18}
D/BluetoothTethering( 2703): startMonitoring: mCsHandler: Handler (com.android.server.ConnectivityService$NetworkStateTrackerHandler) {41f55b18}
D/BluetoothManagerService( 2703): Message: 20
D/BluetoothManagerService( 2703): Added callback: android.bluetooth.BluetoothAdapter$1@41fecb58:true
D/BluetoothManagerService( 2703): Message: 30
W/ContextImpl( 2703): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1543 android.bluetooth.BluetoothPan.doBind:149 android.bluetooth.BluetoothPan.<init>:141 android.bluetooth.BluetoothAdapter.getProfileProxy:1190 android.bluetooth.BluetoothTetheringDataTracker.startMonitoring:116
E/MobileDataStateTracker( 2703): default: Ignoring feature request because could not acquire PhoneService
E/MobileDataStateTracker( 2703): default: Could not enable APN type "default"
I/WifiService( 2703): WifiService starting up with Wi-Fi disabled
I/SystemServer( 2703): Network Service Discovery Service
D/NsdService( 2703): Network service discovery enabled true
I/SystemServer( 2703): UpdateLock Service
I/SystemServer( 2703): Notification Manager
I/SystemServer( 2703): Device Storage Monitor
I/SystemServer( 2703): Location Manager
I/SystemServer( 2703): Country Detector
I/SystemServer( 2703): Search Service
I/SystemServer( 2703): DropBox Service
I/SystemServer( 2703): Wallpaper Service
I/SystemServer( 2703): Audio Service
D/dalvikvm( 2703): GC_CONCURRENT freed 261K, 7% free 4481K/4812K, paused 1ms+5ms, total 30ms
D/EventHub( 2703): No input device configuration file found for device 'WM8962 Beep Generator'.
I/MediaFocusControl( 2703):   Remote Control   registerMediaButtonIntent() for PendingIntent{420148d0: PendingIntentRecord{41fdad60 android broadcastIntent}}
I/SystemServer( 2703): Dock Observer
W/DockObserver( 2703): This kernel does not have dock station support
I/SystemServer( 2703): Wired Accessory Manager
I/SystemServer( 2703): USB Service
I/SystemServer( 2703): Serial Service
I/SystemServer( 2703): Twilight Service
I/SystemServer( 2703): UI Mode Manager Service
I/SystemServer( 2703): Backup Service
V/BackupManagerService( 2703): Initializing package tracking
V/BackupManagerService( 2703): No ancestral data
V/BackupManagerService( 2703): addPackageParticipantsLocked: all
I/BackupManagerService( 2703): Scheduling backup for new app com.android.calendar
D/BackupManagerService( 2703): Now staging backup of com.android.calendar
I/BackupManagerService( 2703): Scheduling backup for new app com.android.browser
D/BackupManagerService( 2703): Now staging backup of com.android.browser
I/BackupManagerService( 2703): Scheduling backup for new app com.android.providers.userdictionary
D/BackupManagerService( 2703): Now staging backup of com.android.providers.userdictionary
I/BackupManagerService( 2703): Scheduling backup for new app com.android.sharedstoragebackup
D/BackupManagerService( 2703): Now staging backup of com.android.sharedstoragebackup
I/BackupManagerService( 2703): Scheduling backup for new app android
D/BackupManagerService( 2703): Now staging backup of android
I/BackupManagerService( 2703): Scheduling backup for new app com.android.dialer
D/BackupManagerService( 2703): Now staging backup of com.android.dialer
I/BackupManagerService( 2703): Scheduling backup for new app com.android.providers.settings
D/BackupManagerService( 2703): Now staging backup of com.android.providers.settings
V/BackupManagerService( 2703): Starting with transport android/com.android.internal.backup.LocalTransport
V/BackupManagerService( 2703): Found transports: 1
I/BackupManagerService( 2703): Binding to transport host ComponentInfo{android/com.android.internal.backup.LocalTransportService}
I/BackupManagerService( 2703): Found stale backup journal, scheduling
I/BackupManagerService( 2703):   com.android.calendar
I/BackupManagerService( 2703):   com.android.browser
I/BackupManagerService( 2703):   com.android.providers.userdictionary
I/BackupManagerService( 2703):   com.android.sharedstoragebackup
I/BackupManagerService( 2703):   android
I/BackupManagerService( 2703):   com.android.dialer
I/BackupManagerService( 2703):   com.android.providers.settings
I/BackupManagerService( 2703): Backup enabled => false
I/BackupManagerService( 2703): Opting out of backup
I/SystemServer( 2703): AppWidget Service
I/SystemServer( 2703): Recognition Service
I/SystemServer( 2703): DiskStats Service
I/SystemServer( 2703): SamplingProfiler Service
I/SystemServer( 2703): NetworkTimeUpdateService
I/SystemServer( 2703): CommonTimeManagementService
I/SystemServer( 2703): CertBlacklister
I/SystemServer( 2703): Dreams Service
I/SystemServer( 2703): Assets Atlas Service
I/SystemServer( 2703): IdleMaintenanceService
D/Atlas   ( 2703): Loaded configuration: SliceMinArea (768x768) flags=0x2 count=24
I/SystemServer( 2703): Print Service
I/SystemServer( 2703): Media Router Service
D/libEGL  ( 2703): loaded /system/lib/egl/libEGL_VIVANTE.so
D/libEGL  ( 2703): loaded /system/lib/egl/libGLESv1_CM_VIVANTE.so
I/InputReader( 2703): Device added: id=-1, name='Virtual', sources=0x00000301
I/InputReader( 2703):   Touch device 'max11801_ts' could not query the properties of its associated display.  The device will be inoperable until the display size becomes available.
I/InputReader( 2703): Device added: id=8, name='max11801_ts', sources=0x00002002
I/InputReader( 2703): Device added: id=7, name='gpio-keys', sources=0x00000101
I/InputReader( 2703): Device added: id=6, name='Logitech USB Optical Mouse', sources=0x00002002
I/InputReader( 2703): Device added: id=5, name='wm8962-audio DMIC', sources=0x80000000
I/InputReader( 2703): Device added: id=4, name='wm8962-audio Headphone Jack', sources=0x80000000
I/InputReader( 2703): Reconfiguring input devices.  changes=0x00000004
I/InputReader( 2703): Device reconfigured: id=8, name='max11801_ts', size 1024x768, orientation 0, mode 4, display id 0
I/WindowManager( 2703): SAFE MODE not enabled
D/dalvikvm( 2703): JIT started for system_server
D/libEGL  ( 2703): loaded /system/lib/egl/libGLESv2_VIVANTE.so
D/dalvikvm( 2703): GC_CONCURRENT freed 222K, 6% free 4663K/4956K, paused 3ms+16ms, total 49ms
I/Zygote  ( 2703): Process: zygote socket opened
V/KeyguardServiceDelegate( 2703): *** Keyguard started
V/KeyguardServiceDelegate( 2703): onSystemReady() called before keyguard service was ready
I/ActivityManager( 2703): Start proc com.android.systemui for service com.android.keyguard/.KeyguardService: pid=2760 uid=10007 gids={50007, 1028, 1015, 1035, 3002, 3001}
I/AppOps  ( 2703): Pruning old package media/1013: new uid=-1
I/ActivityManager( 2703): System now ready
I/SystemServer( 2703): Making services ready
D/NetworkManagementService( 2703): enabling bandwidth control
W/MountService( 2703): Duplicate state transition (mounted -> mounted) for /storage/emulated/0
D/Atlas   ( 2703): Rendered atlas in 245.26ms (1.29+243.97ms)
V/KeyguardService( 2760): onCreate()
E/OMXMaster( 2341): A component of name 'OMX.Freescale.std.parser.fsl.sw-based' already exists, ignoring this one.
E/OMXMaster( 2341): A component of name 'OMX.Freescale.std.parser.streaming.sw-based' already exists, ignoring this one.
D/SystemUIService( 2760): loading: class com.android.systemui.recent.Recents
D/SystemUIService( 2760): running: com.android.systemui.recent.Recents@41e6ae00
D/SystemUIService( 2760): loading: class com.android.systemui.statusbar.SystemBars
D/SystemUIService( 2760): running: com.android.systemui.statusbar.SystemBars@41e6b3e8
D/SystemUIService( 2760): loading: class com.android.systemui.usb.StorageNotification
D/SystemUIService( 2760): running: com.android.systemui.usb.StorageNotification@41e6d1a8
D/SystemUIService( 2760): loading: class com.android.systemui.power.PowerUI
D/SystemUIService( 2760): running: com.android.systemui.power.PowerUI@41e6eba8
D/SystemUIService( 2760): loading: class com.android.systemui.media.RingtonePlayer
D/SystemUIService( 2760): running: com.android.systemui.media.RingtonePlayer@41e6fbd0
D/SystemUIService( 2760): loading: class com.android.systemui.settings.SettingsUI
D/SystemUIService( 2760): running: com.android.systemui.settings.SettingsUI@41e70eb8
D/PhoneStatusBar( 2760): mSettingsPanelGravity = 8388661
I/StatusBarManagerService( 2703): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@42055628
D/dalvikvm( 2760): GC_CONCURRENT freed 141K, 7% free 2945K/3152K, paused 2ms+2ms, total 22ms
D/dalvikvm( 2760): WAIT_FOR_CONCURRENT_GC blocked 20ms
D/dalvikvm( 2760): GC_CONCURRENT freed 19K, 6% free 3331K/3512K, paused 1ms+1ms, total 15ms
D/dalvikvm( 2760): WAIT_FOR_CONCURRENT_GC blocked 13ms
V/PhoneStatusBar/NavigationBarView( 2760): touchEnabled:false
D/BluetoothManagerService( 2703): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@42072600:true
D/BluetoothAdapter( 2760): 1106443656: getState() :  mService = null. Returning STATE_OFF
D/dalvikvm( 2760): GC_CONCURRENT freed 118K, 5% free 3636K/3816K, paused 2ms+4ms, total 19ms
I/ActivityManager( 2703): Start proc android.process.media for broadcast com.android.providers.media/.MtpReceiver: pid=2836 uid=10005 gids={50005, 1028, 1015, 1023, 1024, 2001, 3003, 3007}
I/ActivityManager( 2703): Config changes=200 {1.0 ?mcc?mnc en_US ldltr sw768dp w1024dp h695dp 160dpi xlrg land -touch -keyb/v/h -nav/h s.4}
W/RecognitionManagerService( 2703): no available voice recognition services found for user 0
W/InputMethodManagerService( 2703): Ignoring setImeWindowStatus of uid 1000 token: null
I/ActivityManager( 2703): Start proc android.process.acore for content provider com.android.providers.contacts/.ContactsProvider2: pid=2850 uid=10002 gids={50002, 3003, 1028, 1015}
I/ActivityManager( 2703): Start proc com.android.inputmethod.latin for service com.android.inputmethod.latin/.LatinIME: pid=2862 uid=10029 gids={50029, 1028, 1015}
V/InputMethodManagerService( 2703): Adding window token: android.os.Binder@4209e1b0
D/dalvikvm( 2703): GC_CONCURRENT freed 255K, 7% free 4829K/5156K, paused 3ms+6ms, total 55ms
D/PhoneStatusBar( 2760): disable: < expand icons alerts ticker system_info back home recent clock search >
W/GpsLocationProvider( 2703): Could not open GPS configuration file /etc/gps.conf
W/LocationManagerService( 2703): no network location provider found
E/LocationManagerService( 2703): no geocoder provider found
E/FlpHardwareProvider( 2703): Error hw_get_module 'flp': -2
E/LocationManagerService( 2703): No FusedProvider found.
E/LocationManagerService( 2703): no geofence provider found
I/CommonTimeManagementService( 2703): No common time service detected on this platform.  Common time services will be unavailable.
I/InputReader( 2703): Reconfiguring input devices.  changes=0x00000020
D/GpsLocationProvider( 2703): set_capabilities_callback: 1u
D/athr_gps( 2703): gps entered timer thread
D/athr_gps( 2703): gps entered nmea thread
I/InputReader( 2703): Reconfiguring input devices.  changes=0x00000010
I/ActivityManager( 2703): Start proc com.android.phone for added application com.android.phone: pid=2882 uid=1001 gids={41001, 3002, 3001, 3003, 1028, 1015}
I/ActivityManager( 2703): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.launcher/com.android.launcher2.Launcher} from pid 0
I/ActivityManager( 2703): Start proc com.android.launcher for activity com.android.launcher/com.android.launcher2.Launcher: pid=2892 uid=10008 gids={50008}
I/Choreographer( 2703): Skipped 38 frames!  The application may be doing too much work on its main thread.
I/ActivityManager( 2703): Start proc com.android.printspooler for service com.android.printspooler/.PrintSpoolerService: pid=2905 uid=10038 gids={50038}
V/KeyguardServiceDelegate( 2703): *** Keyguard connected (yay!)
W/InputMethodManagerService( 2703): Focus gain on non-focused client android.view.inputmethod.InputMethodManager$1@4202f1f0 (uid=1000 pid=2703)
I/LatinIME( 2862): Hardware accelerated drawing: true
I/ActivityManager( 2703): Start proc com.android.settings for broadcast com.android.settings/.widget.SettingsAppWidgetProvider: pid=2921 uid=1000 gids={41000, 3003, 1028, 1015, 3002, 3001}
D/BluetoothManagerService( 2703): Message: 300
D/BluetoothManagerService( 2703): MESSAGE_USER_SWITCHED
I/MediaFocusControl( 2703):   Remote Control   registerMediaButtonIntent() for PendingIntent{420a7188: PendingIntentRecord{41fdad60 android broadcastIntent}}
D/dalvikvm( 2760): GC_CONCURRENT freed 100K, 4% free 3993K/4156K, paused 4ms+6ms, total 41ms
D/PhoneStatusBar( 2760): heads up is disabled
V/BackupManagerService( 2703): Connected to transport ComponentInfo{android/com.android.internal.backup.LocalTransportService}
V/BackupManagerService( 2703): Registering transport android/com.android.internal.backup.LocalTransportService::android/com.android.internal.backup.LocalTransport = com.android.internal.backup.LocalTransport@4207bf70
D/dalvikvm( 2850): GC_CONCURRENT freed 198K, 8% free 3010K/3264K, paused 6ms+135ms, total 178ms
D/dalvikvm( 2850): WAIT_FOR_CONCURRENT_GC blocked 4ms
D/libEGL  ( 2760): loaded /system/lib/egl/libEGL_VIVANTE.so
I/PrintSpoolerService( 2905): No existing print spooler state.
D/BluetoothManagerService( 2703): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@420c8a60:true
I/FusedLocation( 2703): engine started (com.android.location.fused)
D/BluetoothAdapter( 2921): 1105635536: getState() :  mService = null. Returning STATE_OFF
D/libEGL  ( 2760): loaded /system/lib/egl/libGLESv1_CM_VIVANTE.so
W/ContextImpl( 2921): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1543 android.content.ContextWrapper.bindService:517 android.bluetooth.BluetoothInputDevice.doBind:245 android.bluetooth.BluetoothInputDevice.<init>:238 android.bluetooth.BluetoothAdapter.getProfileProxy:1187
W/ContextImpl( 2921): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1543 android.content.ContextWrapper.bindService:517 android.bluetooth.BluetoothPan.doBind:149 android.bluetooth.BluetoothPan.<init>:141 android.bluetooth.BluetoothAdapter.getProfileProxy:1190
D/LocalBluetoothProfileManager( 2921): Adding local MAP profile
D/BluetoothMap( 2921): Create BluetoothMap proxy object
D/dalvikvm( 2703): GC_CONCURRENT freed 278K, 7% free 5018K/5368K, paused 2ms+4ms, total 61ms
W/ContextImpl( 2921): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1543 android.content.ContextWrapper.bindService:517 android.bluetooth.BluetoothMap.doBind:109 android.bluetooth.BluetoothMap.<init>:102 android.bluetooth.BluetoothAdapter.getProfileProxy:1196
D/LocalBluetoothProfileManager( 2921): LocalBluetoothProfileManager construction complete
W/ContextImpl( 2921): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1543 android.content.ContextWrapper.bindService:517 android.bluetooth.BluetoothPbap.doBind:164 android.bluetooth.BluetoothPbap.<init>:157 com.android.settings.bluetooth.PbapServerProfile.<init>:68
D/libEGL  ( 2760): loaded /system/lib/egl/libGLESv2_VIVANTE.so
I/ActivityManager( 2703): Start proc com.android.music for broadcast com.android.music/.MediaButtonIntentReceiver: pid=2953 uid=10033 gids={50033, 3003, 1028, 1015}
I/dalvikvm( 2953): Enabling JNI app bug workarounds for target SDK version 9...
D/BluetoothManagerService( 2703): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@4205fed0:true
D/dalvikvm( 2339): GC_EXPLICIT freed 38K, 4% free 2706K/2808K, paused 2ms+2ms, total 48ms
W/InputAttributes( 2862): No editor info for this field. Bug?
I/ResourceUtils( 2862): Found default value: resource=keypress_vibration_durations build=[HARDWARE=freescale MODEL=SABRESD-MX6DQ BRAND=Freescale MANUFACTURER=Freescale] default=-1
I/ResourceUtils( 2862): Found default value: resource=keypress_volumes build=[HARDWARE=freescale MODEL=SABRESD-MX6DQ BRAND=Freescale MANUFACTURER=Freescale] default=-1.0f
D/dalvikvm( 2339): GC_EXPLICIT freed <1K, 4% free 2706K/2808K, paused 4ms+3ms, total 30ms
D/dalvikvm( 2882): GC_CONCURRENT freed 176K, 8% free 2973K/3212K, paused 4ms+2ms, total 49ms
D/dalvikvm( 2339): GC_EXPLICIT freed <1K, 4% free 2706K/2808K, paused 3ms+3ms, total 28ms
E/BufferQueue( 2338): [StatusBar] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
D/CallNotifier( 2882): CallNotifier: mSignalInfoToneGenerator created when toneplay
D/OpenGLRenderer( 2760): Enabling debug mode 0
I/LatinIME:LogUtils( 2862): Dictionary info: dictionary = personalization.en_US.dict ; version = ? ; date = 86498
I/LatinIME:LogUtils( 2862): Dictionary info: dictionary = UserHistoryDictionary.en_US.dic ; version = ? ; date = 86498
I/LatinIME:LogUtils( 2862): Dictionary info: dictionary = userunigram.en_US.dict ; version = ? ; date = ?
E/BufferQueue( 2338): [NavigationBar] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
D/MobileDataStateTracker( 2703): fota: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=fota
D/MobileDataStateTracker( 2703): fota: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker( 2703): supl: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=supl
D/MobileDataStateTracker( 2703): supl: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker( 2703): hipri: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=hipri
D/dalvikvm( 2892): GC_CONCURRENT freed 187K, 8% free 2926K/3176K, paused 4ms+2ms, total 30ms
I/MediaFocusControl( 2703):   Remote Control   registerMediaButtonIntent() for PendingIntent{420508c8: PendingIntentRecord{42077468 com.android.music broadcastIntent}}
D/MobileDataStateTracker( 2703): hipri: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker( 2703): ims: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=ims
D/MobileDataStateTracker( 2703): ims: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker( 2703): default: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=default
D/MobileDataStateTracker( 2703): default: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker( 2703): mms: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=mms
D/MobileDataStateTracker( 2703): mms: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/MobileDataStateTracker( 2703): cbs: Broadcast received: android.intent.action.ANY_DATA_STATE apnType=cbs
I/LatinIME:LogUtils( 2862): Dictionary info: dictionary = PersonalizationPredictionDictio ; version = ? ; date = 86498
D/MobileDataStateTracker( 2703): cbs: Received state=DISCONNECTED, old=DISCONNECTED, reason=radioTurnedOff
D/dalvikvm( 2862): GC_CONCURRENT freed 200K, 9% free 2934K/3196K, paused 3ms+4ms, total 110ms
D/MobileDataStateTracker( 2703): fota: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker( 2703): supl: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker( 2703): hipri: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker( 2703): ims: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker( 2703): default: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker( 2703): mms: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker( 2703): cbs: Received state=DISCONNECTED, old=DISCONNECTED, reason=dataDetached
D/MobileDataStateTracker( 2703): fota: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/MobileDataStateTracker( 2703): supl: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/MobileDataStateTracker( 2703): hipri: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/MobileDataStateTracker( 2703): ims: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/MobileDataStateTracker( 2703): default: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/MobileDataStateTracker( 2703): mms: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/MobileDataStateTracker( 2703): cbs: Received state=DISCONNECTED, old=DISCONNECTED, reason=roamingOff
D/TelephonyDebugService( 2882): TelephonyDebugService()
I/LatinIME:LogUtils( 2862): Dictionary info: dictionary = main:en ; version = 42 ; date = 1381226429
E/BluetoothPhoneService( 2882): Could not get a handle on Connection object for the call
W/CallNotifier( 2882): Got onMwiChanged() on non-voice-capable device! Ignoring...
V/KeyguardServiceDelegate( 2703): **** SHOWN CALLED ****
I/PhoneApp( 2882): Headset phone created, binding local service.
I/Choreographer( 2760): Skipped 35 frames!  The application may be doing too much work on its main thread.
D/dalvikvm( 2892): GC_CONCURRENT freed 127K, 6% free 3239K/3436K, paused 3ms+2ms, total 28ms
I/ContactLocale( 2850): AddressBook Labels [en_US]: [, A, B, C, D, E, F, G, H, I, J, K, L, M, N, O, P, Q, R, S, T, U, V, W, X, Y, Z, Α, Β, Γ, Δ, Ε, Ζ, Η, Θ, Ι, Κ, Λ, Μ, Ν, Ξ, Ο, Π, Ρ, Σ, Τ, Υ, Φ, Χ, Ψ, Ω, , А, Б, В, Г, Д, Е, Є, Ж, З, И, І, Ї, Й, К, Л, М, Н, О, П, Р, С, Т, У, Ф, Х, Ц, Ч, Ш, Щ, Ю, Я, , א, ב, ג, ד, ה, ו, ז, ח, ט, י, כ, ל, מ, נ, ס, ע, פ, צ, ק, ר, ש, ת, , ا, ب, ت, ث, ج, ح, خ, د, ذ, ر, ز, س, ش, ص, ض, ط, ظ, ع, غ, ف, ق, ك, ل, م, ن, ه, و, ي, , ก, ข, ฃ, ค, ฅ, ฆ, ง, จ, ฉ, ช, ซ, ฌ, ญ, ฎ, ฏ, ฐ, ฑ, ฒ, ณ, ด, ต, ถ, ท, ธ, น, บ, ป, ผ, ฝ, พ, ฟ, ภ, ม, ย, ร, ฤ, ล, ฦ, ว, ศ, ษ, ส, ห, ฬ, อ, ฮ, , ㄱ, ㄴ, ㄷ, ㄹ, ㅁ, ㅂ, ㅅ, ㅇ, ㅈ, ㅊ, ㅋ, ㅌ, ㅍ, ㅎ, , あ, か, さ, た, な, は, ま, や, ら, わ, #, ]
D/dalvikvm( 2760): GC_FOR_ALLOC freed 173K, 6% free 4201K/4436K, paused 22ms, total 23ms
D/dalvikvm( 2703): GC_CONCURRENT freed 377K, 9% free 5107K/5556K, paused 2ms+5ms, total 47ms
I/dalvikvm-heap( 2760): Grow heap (frag case) to 13.536MB for 9830416-byte allocation
D/libEGL  ( 2892): loaded /system/lib/egl/libEGL_VIVANTE.so
D/dalvikvm( 2760): GC_CONCURRENT freed 65K, 3% free 13735K/14040K, paused 3ms+3ms, total 26ms
D/libEGL  ( 2892): loaded /system/lib/egl/libGLESv1_CM_VIVANTE.so
D/libEGL  ( 2892): loaded /system/lib/egl/libGLESv2_VIVANTE.so
D/dalvikvm( 2760): GC_FOR_ALLOC freed 1K, 3% free 13739K/14040K, paused 21ms, total 21ms
E/BufferQueue( 2338): [com.android.launcher/com.android.launcher2.Launcher] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
D/OpenGLRenderer( 2892): Enabling debug mode 0
I/dalvikvm-heap( 2760): Grow heap (frag case) to 19.319MB for 6127632-byte allocation
D/dalvikvm( 2760): GC_CONCURRENT freed 1K, 2% free 19721K/20028K, paused 2ms+2ms, total 20ms
D/dalvikvm( 2760): WAIT_FOR_CONCURRENT_GC blocked 18ms
E/BufferQueue( 2338): [com.android.systemui.ImageWallpaper] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
I/ActivityManager( 2703): Displayed com.android.launcher/com.android.launcher2.Launcher: +1s225ms
D/dalvikvm( 2892): GC_CONCURRENT freed 203K, 8% free 3426K/3692K, paused 3ms+2ms, total 26ms
I/Choreographer( 2760): Skipped 31 frames!  The application may be doing too much work on its main thread.
D/dalvikvm( 2892): GC_FOR_ALLOC freed 12K, 7% free 3648K/3920K, paused 22ms, total 22ms
D/dalvikvm( 2892): GC_FOR_ALLOC freed <1K, 7% free 3873K/4148K, paused 16ms, total 16ms
I/SurfaceFlinger( 2338): Boot is finished (16435 ms)
W/ContextImpl( 2703): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1543 android.bluetooth.BluetoothHeadset.doBind:283 android.bluetooth.BluetoothHeadset.<init>:276 android.bluetooth.BluetoothAdapter.getProfileProxy:1181 android.media.AudioService.getBluetoothHeadset:2249
D/dalvikvm( 2892): GC_CONCURRENT freed 57K, 4% free 4228K/4376K, paused 4ms+3ms, total 24ms
W/ContextImpl( 2703): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1543 android.bluetooth.BluetoothA2dp.doBind:165 android.bluetooth.BluetoothA2dp.<init>:158 android.bluetooth.BluetoothAdapter.getProfileProxy:1184 android.media.AudioService$AudioServiceBroadcastReceiver.onReceive:4170
V/WiredAccessoryManager( 2703): init()
V/WiredAccessoryManager( 2703): newName=h2w newState=2 headsetState=2 prev headsetState=0
W/WiredAccessoryManager( 2703): /sys/class/switch/usb_audio/state not found while attempting to determine initial switch state
V/WiredAccessoryManager( 2703): device h2w connected
I/RecoverySystem( 2703): No recovery log file
I/ActivityManager( 2703): Start proc com.android.providers.calendar for broadcast com.android.providers.calendar/.CalendarReceiver: pid=3000 uid=10001 gids={50001, 3003, 1028, 1015}
I/BootReceiver( 2703): Copying audit failures to DropBox
I/BootReceiver( 2703): Checking for fsck errors
D/dalvikvm( 2892): GC_FOR_ALLOC freed 135K, 6% free 4336K/4592K, paused 17ms, total 18ms
I/dalvikvm-heap( 2892): Grow heap (frag case) to 5.524MB for 1290512-byte allocation
I/CalendarProvider2( 3000): Created com.android.providers.calendar.CalendarAlarmManager@41e6c8d0(com.android.providers.calendar.CalendarProvider2@41e645a0)
D/dalvikvm( 2892): GC_CONCURRENT freed 5K, 5% free 5591K/5856K, paused 2ms+1ms, total 19ms
D/dalvikvm( 2892): WAIT_FOR_CONCURRENT_GC blocked 12ms
I/ActivityManager( 2703): Delay finish: com.android.providers.downloads/.DownloadReceiver
I/ActivityManager( 2703): Resuming delayed broadcast
I/ActivityManager( 2703): Delay finish: com.android.providers.media/.MediaScannerReceiver
I/PowerManagerService( 2703): Boot animation finished.
W/audio_hw_primary( 2341): out_set_parameters routing=0, ret 1, out 1074472776
I/AudioRouter( 2882): Audio mode changing to WIRED_HEADSET
D/dalvikvm( 2836): GC_CONCURRENT freed 213K, 9% free 2875K/3152K, paused 2ms+2ms, total 18ms
D/dalvikvm( 2836): GC_CONCURRENT freed 239K, 10% free 3035K/3336K, paused 2ms+2ms, total 17ms
V/MediaScanner( 2836): pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@41ea5560
V/MediaScanner( 2836): /pruneDeadThumbnailFiles... android.database.sqlite.SQLiteCursor@41ea5560
I/ActivityManager( 2703): Start proc com.android.mms for broadcast com.android.mms/.transaction.MmsSystemEventReceiver: pid=3042 uid=10009 gids={50009, 3003, 1028, 1015}
D/CountryDetector( 2703): The first listener is added
V/MmsConfig( 3042): mnc/mcc:
V/MmsConfig( 3042): tag: bool value: enabledMMS - true
V/MmsConfig( 3042): tag: int value: maxMessageSize - 307200
V/MmsConfig( 3042): tag: int value: maxImageHeight - 480
V/MmsConfig( 3042): tag: int value: maxImageWidth - 640
V/MmsConfig( 3042): tag: int value: defaultSMSMessagesPerThread - 10000
V/MmsConfig( 3042): tag: int value: defaultMMSMessagesPerThread - 1000
V/MmsConfig( 3042): tag: int value: minMessageCountPerThread - 10
V/MmsConfig( 3042): tag: int value: maxMessageCountPerThread - 5000
V/MmsConfig( 3042): tag: string value: uaProfUrl - http://www.google.com/oha/rdf/ua-profile-kila.xml
V/MmsConfig( 3042): tag: int value: recipientLimit - -1
V/MmsConfig( 3042): tag: bool value: enableMultipartSMS - true
V/MmsConfig( 3042): tag: int value: smsToMmsTextThreshold - -1
V/MmsConfig( 3042): tag: bool value: enableSlideDuration - true
V/MmsConfig( 3042): tag: int value: maxMessageTextSize - -1
I/ActivityManager( 2703): Delay finish: com.android.mms/.transaction.MmsSystemEventReceiver
D/Mms:app ( 3042): cancelNotification
I/ActivityManager( 2703): Delay finish: com.android.mms/.transaction.SmsReceiver
I/ActivityManager( 2703): Start proc com.android.onetimeinitializer for broadcast com.android.onetimeinitializer/.OneTimeInitializerReceiver: pid=3068 uid=10011 gids={50011}
V/OneTimeInitializerRece( 3068): OneTimeInitializerReceiver.onReceive
I/ActivityManager( 2703): Delay finish: com.android.onetimeinitializer/.OneTimeInitializerReceiver
I/ActivityManager( 2703): Start proc com.android.calendar for broadcast com.android.calendar/.alerts.AlertReceiver: pid=3082 uid=10019 gids={50019, 3003}
D/ExtensionsFactory( 3082): No custom extensions.
D/AlertReceiver( 3082): onReceive: a=android.intent.action.BOOT_COMPLETED Intent { act=android.intent.action.BOOT_COMPLETED flg=0x8000010 cmp=com.android.calendar/.alerts.AlertReceiver (has extras) }
D/AlertService( 3082): 0 Action = android.intent.action.BOOT_COMPLETED
I/ActivityManager( 2703): Delay finish: com.android.calendar/.alerts.AlertReceiver
D/AlertService( 3082): Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null
D/AlarmScheduler( 3082): No events found starting within 1 week.
I/CalendarProvider2( 3000): Sending notification intent: Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar }
W/ContentResolver( 3000): Failed to get type for: content://com.android.calendar (Unknown URL content://com.android.calendar)
I/ActivityManager( 2703): Start proc com.android.deskclock for broadcast com.android.deskclock/.AlarmInitReceiver: pid=3101 uid=10023 gids={50023, 1028}
V/AlarmClock( 3101): AlarmInitReceiver android.intent.action.BOOT_COMPLETED
V/AlarmClock( 3101): AlarmInitReceiver - Reset timers and clear stopwatch data
I/AlarmClock( 3101): Displaying next alarm time: ''
V/AlarmClock( 3101): AlarmInitReceiver finished
I/ActivityManager( 2703): Start proc com.android.email for broadcast com.android.email/.service.EmailBroadcastReceiver: pid=3116 uid=10025 gids={50025, 3003, 1028, 1015}
D/ActivityThread( 3116): Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
I/ActivityManager( 2703): Delay finish: com.android.email/.service.EmailBroadcastReceiver
D/dalvikvm( 3116): GC_CONCURRENT freed 203K, 9% free 2899K/3172K, paused 2ms+2ms, total 17ms
I/Email   ( 3116): Observing account changes for notifications
W/ActivityManager( 2703): Unable to start service Intent { cmp=com.android.email/.service.AttachmentDownloadService } U=0: not found
I/ActivityManager( 2703): Delaying start of: ServiceRecord{420a8558 u0 com.android.exchange/.service.EmailSyncAdapterService}
I/ActivityManager( 2703): Start proc com.android.exchange for service com.android.exchange/.service.EmailSyncAdapterService: pid=3138 uid=10026 gids={50026, 3003, 1028, 1015}
I/LauncherIconVisibilityManager( 2862): Boot has been completed
I/LauncherIconVisibilityManager( 2862): Activity has already been disabled: ComponentInfo{com.android.inputmethod.latin/com.android.inputmethod.latin.setup.SetupActivity}
V/SmsReceiverService( 3042): onStart: #1 mResultCode: -1 = Activity.RESULT_OK
D/AlertReceiver( 3082): onReceive: a=android.intent.action.PROVIDER_CHANGED Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar flg=0x10 cmp=com.android.calendar/.alerts.AlertReceiver }
D/AlertService( 3082): 0 Action = android.intent.action.PROVIDER_CHANGED
I/GlobalDismissManager( 3082): no sender configured
D/AlertService( 3082): Beginning updateAlertNotification
D/AlertService( 3082): No fired or scheduled alerts
I/ActivityManager( 2703): Delay finish: com.android.providers.calendar/.CalendarProviderBroadcastReceiver
I/ActivityManager( 2703): Waited long enough for: ServiceRecord{420d33b8 u0 com.android.music/.MediaPlaybackService}
I/ActivityManager( 2703): Waited long enough for: ServiceRecord{420c0d78 u0 com.android.calendar/.alerts.InitAlarmsService}
D/InitAlarmsService( 3082): Clearing and rescheduling alarms.
I/OMXClient( 3176): Using client-side OMX mux.
I/vpu-lib ( 2341): Product Info: i.MX6Q/D/S
E/OMXNodeInstance( 2341): OMX_SetParameter() failed for StoreMetaDataInBuffers: 0x8000101a
E/ACodec  ( 3176): [OMX.Freescale.std.video_encoder.avc.hw-based] storeMetaDataInBuffers (output) failed w/ err -2147483648
I/ACodec  ( 3176): setupVideoEncoder succeeded
I/vpu-lib ( 2341): <gpu> alloc handle: 0x40ae4c68, paddr: 0x4340e000, vaddr: 0x420f2000
I/vpu-lib ( 2341): <gpu> alloc handle: 0x40bf1768, paddr: 0x43410000, vaddr: 0x420f4000
I/vpu-lib ( 2341): <gpu> alloc handle: 0x40bf1918, paddr: 0x43412000, vaddr: 0x420f6000
I/vpu-lib ( 2341): <gpu> alloc handle: 0x40c83c98, paddr: 0x43d0b000, vaddr: 0x429ef000
I/vpu-lib ( 2341): <gpu> alloc handle: 0x40c83e78, paddr: 0x43e0c000, vaddr: 0x42af0000
I/vpu-lib ( 2341): <gpu> alloc handle: 0x40c5bc70, paddr: 0x43f0d000, vaddr: 0x42bf1000
W/SurfaceFlinger( 2338): [ScreenRecorder] Unexpected dequeueBuffer() in IDLE state
W/SurfaceFlinger( 2338): [ScreenRecorder] EGL called dequeueBuffer with !async despite eglSwapInterval(0)
E/SurfaceFlinger( 2338): [ScreenRecorder] dequeueBuffer: no buffer, bailing out
E/v_egl   ( 2338): Failed to dequeue buffer
W/SurfaceFlinger( 2338): [ScreenRecorder] Unexpected beginFrame() in GLES state
E/        ( 2341): Not supported color format 4!
I/vpu-lib ( 2341): <gpu> alloc handle: 0x40046e38, paddr: 0x4431b000, vaddr: 0x42fff000
I/vpu-lib ( 2341): <gpu> alloc handle: 0x40046e60, paddr: 0x43988000, vaddr: 0x4266c000
I/vpu-lib ( 2341): ringBufferEnable 0, chromaInterleave 1, mapType 1, linear2TiledEnable 1
I/vpu-lib ( 2341): <gpu> alloc handle: 0x40046e88, paddr: 0x4449d000, vaddr: 0x43181000
I/vpu-lib ( 2341): <gpu> alloc handle: 0x40046eb0, paddr: 0x46552000, vaddr: 0x45236000
I/vpu-lib ( 2341): <gpu> alloc handle: 0x40046ed8, paddr: 0x46674000, vaddr: 0x45358000
I/vpu-lib ( 2341): <gpu> alloc handle: 0x40046f00, paddr: 0x46796000, vaddr: 0x4547a000
I/MPEG4Writer( 3176): limits: 2147483647/0 bytes/us, bit rate: -1 bps and the estimated moov size 3072 bytes
I/MPEG4Writer( 3176): setStartTimestampUs: 70077627
I/MPEG4Writer( 3176): Earliest track starting time: 70077627
I/v_hwc   ( 2338): Display(0x4043c008) detected: format=306 1024x768
I/v_hwc   ( 2338): Display buffer(0x4009e270) detected: physical=0x379d2200
D/ConnectivityService( 2703): Sampling interval elapsed, updating statistics ..
D/ConnectivityService( 2703): Done.
D/ConnectivityService( 2703): Setting timer for 720seconds
D/dalvikvm( 2703): GC_CONCURRENT freed 400K, 9% free 5219K/5692K, paused 4ms+3ms, total 43ms
I/MediaFocusControl( 2703):  AudioFocus  abandonAudioFocus() from android.media.AudioManager@41e63800com.android.music.MediaPlaybackService$3@41e62680
I/ActivityManager( 2703): Start proc com.android.musicfx for broadcast com.android.musicfx/.ControlPanelReceiver: pid=3193 uid=10010 gids={50010, 3003, 3002}
V/MusicFXControlPanelReceiver( 3193): onReceive
V/MusicFXControlPanelReceiver( 3193): Action: android.media.action.CLOSE_AUDIO_EFFECT_CONTROL_SESSION
V/MusicFXControlPanelReceiver( 3193): Package name: com.android.music
V/MusicFXControlPanelReceiver( 3193): Audio session: 7
V/MusicFXControlPanelEffect( 3193): closeSession(android.app.ReceiverRestrictedContext@41e5eb08, com.android.music, 7)
