These projects contain only one CPU bean 8346 but can be easily used with
other DSP derivatives by changing the CPU bean in the project.
The MicroC/OS-II source files should be copied into the "Source" subdirectory.
The system path to the MicroC/OS-II sources should be added in the CodeWarrior
Access paths/System paths preference panel if necessary.
