About IMX28 wpa_supplicant
pt
Senior Contributor I
Hi Qiang_FSL
I have selected wpa_supplicant package in ltib and build successfully.
But I couldn't find wpa_supplicant.conf. It is missing.
Best Regards
Parvathy
Labels (2)
Tags (2)
LeonardoSandova
Specialist I
Does your PATH system variable includes the folder where the binary is located? you may try
export PATH=/usr/local/sbin:$PATH
pt
The wpa_supplicant found in usr/local/sbin/ location
root@freescale /usr/local/sbin$ ls -l
-rwxr-xr-x    1 root     root         80346 Aug 27  2014 wpa_cli
-rwxr-xr-x    1 root     root         71860 Aug 27  2014 wpa_passphrase
-rwxr-xr-x    1 root     root        614353 Aug 27  2014 wpa_supplicant
But couldn't find its conf file
pt
found ap_config.conf file.
/usr/etc/unifi/ap_config.conf
ctrl_interface=/var/run/wpa_supplicant
update_config=1
network={
        ssid="cisco-2"
        key_mgmt=NONE
        auth_alg=OPEN
        disabled=1
        id_str="p2"
But wpa_supplicant.conf is missing.
pt
I have checked the wpa_supplicant.spec. Found that conf file of this package is ap_config.conf.
pt
Hi Qiang_FSL
when I tried  wpa_supplicant command ,I am  getting command not found message.
How to solve the issue.
Pt
LeonardoSandova
Specialist I
pt
Thank you.It works.
Pt
alejandrolozan1
Have you tried to find that commnad?
find -name  wpa_supplicant
from root directory? Perhaps it is found in othe r
I wonder if LTIB performed the installation of the packaged in the rootfs. How did you install the package?
Have you tried Yocto?
Alejandro
qiang_li-mpu_se
Sorry, I haven't tried wpa_supplicant in Linux.
