Processor Expert and erasing flash
phlp
Hi all,
I'm using Processor Expert with  CW 10.4 on a MCF51QU32VFM (coldfire+).  I'm trying to write data to the internal flash. I've inserted a flash component using Processor Expert and defined a 1KB flash space at 0x200000 (where the DFlash starts). I copied the functions from the demo projects packaged with CW to erase, read and write to the flash. The following events methods have been defined in Events.c:
void FLASH1_OnOperationComplete(LDD_TUserData *UserDataPtr)
  uint8_t *OpStatus = (LDD_TUserData*) UserDataPtr;
  *OpStatus = TRUE;
void FLASH1_OnError(LDD_TUserData *UserDataPtr)
In my main function I first try to erase the 1KB of flash by calling the following function:
bool EraseFlash(LDD_TDeviceData *DeviceData, LDD_FLASH_TAddress FromAddress, LDD_FLASH_TDataSize Size, uint8_t* OpStatus)
  LDD_TError Error;
  int i = 0;
  *OpStatus = FALSE;
  Error = FLASH1_Erase(DeviceData, FromAddress, Size);
  if (Error) {
    return FALSE;
  while(*OpStatus != TRUE);
  return TRUE;
When FLASH1_Erase(..) is called in the above function, the FLASH1_OnError(..) event is triggered although  FLASH1_Erase(..) returns with no error. FLASH1_OnOperationComplete(.. ) is never triggered, so EraseFlash(..) is stuck in an infinite loop at while(*OpStatus != TRUE).
Any help will be appreciated.
Philip
ZhangJennie
Hi Philip.
can you please try the same with CW10.6?
https://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=CW-MCU10&tid=CWH
if the problem persists in CW10.6, please upload your testing demo code. We will check it here. thansk!
ZhangJun
ZhangJennie
Hi Philip.
ZhangJun
