Cannot transmit serial data over UART0 in FRDM-KE02Z
Question asked by Gaston Schelotto on Aug 25, 2014
Latest reply on Aug 27, 2014 by Gaston Schelotto
I'm trying to send data over UART0 in KE02Z board but I cannot get the Tx signal in the oscilloscope. I'm using KDS 1.1.0 and PE for the drivers initialization and management. I've created an AS1:AsynchroSerial component with the next configuration:
and checked all Initialization options.
The application code is:
AS1_Init();
AS1_SendChar('a');
At the end I expected to see the Tx signal of 'a' on PTB1 however I get a constant zero signal.
Did I miss something?
regards,
gaston
