bitbake error in SDK 1.4 Ubuntu 12.04 ( T4240 )
Question asked by aravind ganesan on Aug 23, 2014
Latest reply on Aug 26, 2014 by aravind ganesan
Branched to a new discussion
I have to build an image for T4240.
I am using SDK 1.4 , Ubuntu 12.04.
I have setup the host environemnt,reconfigured kernel,performed the build procesure.
But when i give the command :
aravind@Aravind:~/yocto/build_t4240qds_release$ bitbake fsl-image-core
The program 'bitbake' is currently not installed.  You can install it by typing:
sudo apt-get install bitbake
aravind@Aravind:~/yocto/build_t4240qds_release$ sudo apt-get install bitbake
Processing triggers for python-support ...
Traceback (most recent call last):
  File "/usr/bin/bitbake", line 234, in <module>
    ret = main()
  File "/usr/bin/bitbake", line 197, in main
    server = ProcessServer(server_channel, event_queue, configuration)
  File "/usr/lib/pymodules/python2.7/bb/server/process.py", line 78, in __init__
    self.cooker = BBCooker(configuration, self.register_idle_function)
  File "/usr/lib/pymodules/python2.7/bb/cooker.py", line 76, in __init__
    self.parseConfigurationFiles(self.configuration.file)
  File "/usr/lib/pymodules/python2.7/bb/cooker.py", line 510, in parseConfigurationFiles
    data = _parse(os.path.join("conf", "bitbake.conf"), data)
TypeError: getVar() takes exactly 3 arguments (2 given)
ERROR: Error evaluating '${TARGET_OS}:${TRANSLATED_TARGET_ARCH}:build-${BUILD_OS}:pn-${PN}:${MACHINEOVERRIDES}:${DISTROOVERRIDES}:${CLASSOVERRIDE}:forcevariable'
  File "/usr/lib/pymodules/python2.7/bb/data_smart.py", line 116, in expandWithRefs
    s = __expand_var_regexp__.sub(varparse.var_sub, s)
  File "/usr/lib/pymodules/python2.7/bb/data_smart.py", line 60, in var_sub
    var = self.d.getVar(key, 1)
  File "/usr/lib/pymodules/python2.7/bb/data_smart.py", line 260, in getVar
    return self.expand(value, var)
  File "/usr/lib/pymodules/python2.7/bb/data_smart.py", line 132, in expand
    return self.expandWithRefs(s, varname).value
  File "/usr/lib/pymodules/python2.7/bb/data_smart.py", line 117, in expandWithRefs
    s = __expand_python_regexp__.sub(varparse.python_sub, s)
ERROR: Error evaluating '${@bb.parse.BBHandler.vars_from_file(d.getVar('FILE'),d)[0] or 'defaultpkgname'}'
  File "/usr/lib/pymodules/python2.7/bb/data_smart.py", line 76, in python_sub
    value = utils.better_eval(codeobj, DataContext(self.d))
  File "/usr/lib/pymodules/python2.7/bb/utils.py", line 387, in better_eval
    return eval(source, _context, locals)
  File "PN", line 1, in <module>
What is the problem?
Please help.
Aravind
