First try of MQX 4.1
Question asked by Eric_t d on Aug 18, 2014
Latest reply on Aug 19, 2014 by soledad
Hi everybody,
Currently I am working with HCS12 controllers and now I am going to make the big step to kinetis controllers.
I will use MK40 and MQX OS.
Currently I am trying to familiarize myself with MQX; the whole thing of RTOS is complete new for me.
I have installed MQX 4.1 and codewarrior 10.6.
I have made the following steps:
-New MQX 4.1 project
-kwikstik board
-new application
-no additional mqx libraries
-empty application
When I compile the project, the following error and warnings occur:
Error
DescriptionResourcePathLocationType
mingw32-make: *** No rule to make target `C:/Freescale/Freescale_MQX_4_1/lib/kwikstikk40x256.cw10gcc/debug/bsp/intflash.ld', needed by `explicit-dependencies'.  Stop.MQX_Prg1C/C++ Problem
Warnings
Invalid project path: Include path not found (C:\Freescale\Freescale_MQX_4_1\lib\kwikstikk40x256.cw10gcc\debug\bsp).MQX_Prg1pathentryPath Entry Problem
Invalid project path: Include path not found (C:\Freescale\Freescale_MQX_4_1\lib\kwikstikk40x256.cw10gcc\debug\bsp\Sources).MQX_Prg1pathentryPath Entry Problem
Invalid project path: Include path not found (C:\Freescale\Freescale_MQX_4_1\lib\kwikstikk40x256.cw10gcc\debug\bsp\Generated_Code).MQX_Prg1pathentryPath Entry Problem
It is expected that an empty application created by wizard should work (compile).
Could anyone tell what is going wrong?
Sorry if it is silly question but the RTOS and Kinetis are complete new for me.
I have attached a screenshot and the project.
Thank you
Original Attachment has been moved to: MQX_Prg1.zip
