Has anyone use the FRDM KL25Z with the CC1125 RF Narrowband Transceiver from Texas Instruments ?
perharaldhelges
I`m having problems transmitting packets. The configuration seem to be working correctly. I`m using a logic analyzer so I am pretty sure that the cicuit is set up correctly. Strobing the transmit command (0x35) should start a transmission of the FIFO buffer but nothing seems to happen. I`m using a spectrum analyzer with antenna to detect the signal.
Paul_Tian
Hi, Helgesen
You can find sample code for CC1125 on TI MCU. But I think you can porting from this sample code.
Link http://www.ti.com/product/CC1125/toolssoftware#softTools
Best Regards
Paul
perharaldhelges
Thanks :smileyhappy:
