MFS Multiple file open
nitinkothari
I am using MFS with MQX on MCF54418.
If I try to open second file with one file already open, the fopen returns NULL and it fails.
This is how I am opening File1.txt :
//Declare File system structure
typedef struct
  MQX_FILE_PTR DEV_FD_PTR;
  MQX_FILE_PTR PM_FD_PTR;
  MQX_FILE_PTR FS_FD_PTR;
  char_ptr     DEV_NAME;
  char_ptr     PM_NAME;
  char_ptr     FS_NAME;
} USB_FILESYSTEM_STRUCT, _PTR_ USB_FILESYSTEM_STRUCT_PTR;
//Create an instance
USB_FILESYSTEM_STRUCT stUsbFileSystem;
//Open File1.txt
stUsbFileSystem.FS_FD_PTR = fopen("C:\\File1.txt", "r");
Now my question is, how to proceed if I have  to open File2.txt without closing File1.txt ?
Any help is greatly appreciated !
Nitro
Luis_Garabo
Hi Nitin,
Try something like this:
void my_task(uint32_t temp)
    FILE_PTR      fp;
    FILE_PTR      fp_temp;
    _time_delay(2000);
    printf("Before write in files\n");
    fp = fopen("a:\\test.txt","a+");
    write(fp, "Hello World", 11);
    fp_temp = fopen("a:\\test_t.txt","a+");
    write(fp_temp, "Hello World_Temp", 18);
    fclose(fp);
    fclose(fp_temp);
    _task_block();
Garabo
Luis_Garabo
Hi Nitin,
    FILE_PTR      fp;
    FILE_PTR      fp_temp;
    _time_delay(2000);
    fclose(fp);
    fclose(fp_temp);
    _task_block();
Garabo
nitinkothari
Thanks Garabo !
It worked for me. I tried the same thing earlier but it somehow failed.
Thank you again !
Nitin
